I am interested in creating a couple custom Fixlets to create Scheduled Tasks in Windows.
The relevance needs to be for Windows XP and to check to see if the is already a .job file with a certain name in the Task Scheduler folder(C:\Windows\tasks). The action is 2 separate command line prompts, one to schedule a Disk Cleanup and one to schedule a Disk Defrag. The action also needs to include the writing of a few new registry keys.
I have complied the command line prompts and needed registry strings and values which are attached in a notepad file. I don’t know a lot about writing scripts so i am having trouble at this point in the process. If someone could please help me out that would be very much appreciated. Thank you so much!
exists value “StateFlag” whose (it as integer != 0) of keys (“Downloaded Program Files”;“Internet Cache Files”;“Recycle Bin”;“Temporary Files”;“WebClient and WebPublisher Cache”;“Compress old files”;“Content Indexer Cleaner”;“Offline Page Files”) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches” of registry
I didn’t test this, but you can use the Fixlet Debugger at: http://support.bigfix.com/fixlet/ to test out the components and make sure they do what you want…
