Need help with parsing a file
(imported topic written by jaf0onl91)
Hello. I have a text file which I need to parse through and count the number of times the following string occurs, “Error finding domain.”. The text file is located in c:\temp and the name of the file is xyz.txt as an example.
The text file contains many lines and the “Error finding domain.” will appear on a line of it’s own.
Any help would be appreciated.
number of lines whose (it contains “Error finding domain.”) of file “c:\temp\xyz.txt”
(imported comment written by jaf0onl91)
Thank you so much !!!
