Need help with a cfg file. (Search and Replace)
(imported topic written by jcsUTSW)
I know I’ve done this before but I can’t find the action I wrote before and cant remember how I did it.
In a nutshell I need to find “BESClient” in a configuration XML file and replace it with “BES Client”
This is the path to the file… “{(value “etcpath” of key “HKLM\SOFTWARE\BBWin” of registry as string & “\BBWin.cfg”)}”
Another question while I have your attention…
In that same file if I wanted to add a new line or several new lines above the line that looks like this “” how would I do that? Actually I guess the help I get from above could help with that… I could just search for “” and replace with
Line One
Line Two
Maybe?
As always any help greatly appreciated…
Here are a few threads that show how to replace or add text to a file.
http://forum.bigfix.com/viewtopic.php?id=1483
http://forum.bigfix.com/viewtopic.php?id=1521
http://forum.bigfix.com/viewtopic.php?id=1961
http://forum.bigfix.com/viewtopic.php?id=2023
http://forum.bigfix.com/viewtopic.php?id=2147
(imported comment written by jcsUTSW)
Ok so I’ve got the line replacement down…
What if I needed to replace a small section of text… 5 or 6 lines.
For example… This is a piece of a configuration file.
I need to replace everything beween and with lines that are similar but have different values.
I cant just search for warnlevel= because there are many instances of that in this config file so I think the best way would be to edit the file, find lines between and nuke them all and put the new lines back.
As always, your help is greatly appreciated…
It gets a little tough to do what you want strictly in relevance, but it is possible:
createfile until __ENDCREATE
{ concatenation “%0D%0A” of
if
line number of item 2 of it > item 0 of it
AND
line number of item 2 of it < item 1 of it
then
if
line number of item 2 of it = item 1 of it - 1
then
“new line 1” ; “new line 2”; “new line 3”
else
nothing
else
item 2 of it
of
line number of line
whose
it starts with “”
of it, line number of lines
whose
it starts with “”
of it, lines of it
of file “c:\foo.txt”}
__ENDCREATE
Basically I create a tuple in the form (start line number, end line number, file lines) and then I go through each file line. If the line number is not between the delimiters, then just return the line. If the line number is between the delimiters then throw it away, unless it’s the the line right before the end delimiter. If it’s the line just before the delimiter, replace it with a list of the new lines. Finally concatenate all the lines together with CRLF.
Jesse
Completed createfile until __ENDCREATE
Failed { concatenation “%0D%0A” of
if
AND
then
if
then
else
nothing
else
item 2 of it
of
line number of line
whose
it starts with “”
whose
it starts with “”
of it, lines of it
__ENDCREATE
/shrug
any ideas?
yeah.
  1. change the file path at the end so it points at your file instead of “c:\foo.txt”
  2. escape the quotes in the xml attribute values: “”
Jesse
Still failing… I tried replacing the quotes with %22.
As far as the foo.txt I made a copy of the config file and just copied it there for testing purposes… Once the edit works then I can swap in the path to the actual file…
I appreciate the help… Any other ideas?
It works for me. This is my action script:
{concatenation “%0D%0A” of (if (line number of item 2 of it > item 0 of it AND line number of item 2 of it < item 1 of it) then ((if (line number of item 2 of it = item 1 of it - 1) then (("" ; “”; “”)) else (nothing))) else (item 2 of it)) of (line number of line whose (it starts with “”) of it, line number of lines whose (it starts with “”) of it, lines of it) of file “c:\foo.txt”}
__ENDCREATE
Here’s the source file c:\foo.txt:
pre
stuff
post stuff
Here is the output in __createfile
pre
stuff
post stuff
Note, there is a double ‘’ line because you included it in your list of subtituion lines. You probably want to remove that.
{concatenation “%0D%0A” of (if (line number of item 2 of it > item 0 of it AND line number of item 2 of it < item 1 of it) then ((if (line number of item 2 of it = item 1 of it - 1) then (("" ; “”;“blah blah blah blah”; “”)) else (nothing))) else (item 2 of it)) of (line number of line whose (it starts with “”) of it, line number of lines whose (it starts with “”) of it, lines of it) of file “c:\foo.txt”}
__ENDCREATE
That’s the action… It says it’s completing just fine now but there are no edits to the file.
I’ve made sure that c:\foo.txt is there and I’ve put only the to section in there and it’s not editing…
/shrug
Any ideas?
Thanks for the continued help.
The file that gets created will be called __createfile. You need to delete the original and then move the file back in place. Full action:
__ENDCREATE
delete c:\foo.txt
move __createfile c:\foo.txt
If that’s not the problem, then what do you see when you evaluate the expression in the relevance debugger?
