We have certain string value in this :-- Like
Name Type Data
1 REG_SZ 10.80.10.12
2 REG_SZ 10.81.2.32
3 REG_SZ 10.100.2.34
In the above tree we have multiple string value but we want to remove specific value based on “Value Name” (Data).
example deleting of
The relevance to detect the key should be something like: (If i understood that correctly)
exists values whose(name of it contains "10.100.2.34") of keys "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\SNMP\Parameters\TrapConfiguration\communitystring" of registries
This relevance should return all the names/values:
(name of it & " = " & it as string) of values of keys "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\SNMP\Parameters\TrapConfiguration\communitystring" of registries
In the above image . as mentioned i need to find the registry value with the IP : 10.150.100.56 and delete it.
So from the tree the specific sets of IP.
the first step is to detection is to get relevance that will return all the values properly. The screenshot helps.
Does this work?
(name of it & " = " & it as string) of values of keys of keys "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\SNMP\Parameters\TrapConfiguration" of registries
