I created a Web Report that displays the existing Google Chrome versions, and I included a chart to enhance its visual presentation. I’m now planning to schedule the report so that it is emailed to me daily.
The challenge is that only the data appears in the email—the chart is not included. Is there a way to achieve this, or is it not possible through the standard BigFix report scheduling? I understand that it might be doable by writing a custom session relevance report using HTML and JavaScript, but I’m hoping to find an existing solution.
One of the easiest way is to enable pdf reports. Default one will not export the chart, only data. Another way is to use lwmailer.exe as demonstratedWelcome to Wikis
Also ensure your SMTP allows large attachments as charts may increase the size of file more than default value.
