system
1
(imported topic written by chrism91)
So i’m trying to do the upgrade for netbackup and need a little help.
I grab the whole upgrade folder/directory and deploy that to the server under the __Download then from there i want to run the silentpatch.cmd file.
This is what i have for my command. Shouldn’t this work? What am i doing wrong?
extract NBUv655maint.tmp
waithidden cmd /C __Download\NBUv655maint\silentpatch.cmd
Thank you in advance for any help
chris
BenKus
2
Add “cd __Download” as the first line of the cmd file and see it that helps…
system
3
(imported comment written by chrism91)
So i would be looking at something like this with the quotes:
waithidden cmd /C “cd__Download\NBUv655maint\silentpatch.cmd”
Thank you Ben for your help.
BenKus
4
Hi Chris,
Actually, I meant change the silentpatch.cmd to include a line “cd __Download” as the first line in the file.
system
5
Thanks for the help. We saw this http://forum.bigfix.com/viewtopic.php?id=4671 that you posted a solution for back in Feb. talking about the netbackup silentpatch.cmd file.
This is what i ended up with that worked for us.
createfile until END
@echo off
cd “C:\Program Files (x86)\BigFix Enterprise\BES Client__BESData\actionsite__Download”
call “silentpatch.cmd”
END
copy __Createfile runme.bat
waithidden cmd.exe /C runme.bat
BenKus
6
Hi Chris,
It is better to use:
cd __Download
rather than
