Hi Team,
I want to create a bigfix custom fixlet which has below command to run on aix/linux boxes to delete select users. Can anybody please help…
note: /usr/seos/bin/selang -c 'ru unix
//Shell to Action Script Conversion Utility
delete __appendfile
appendfile /usr/seos/bin/selang -c 'ru unix
//modify appendfile to allow execution
wait chmod 555 "{(client folder of current site as string) & “/__appendfile”}
//execute shell script as written
wait “{(client folder of current site as string) & “/__appendfile”}”
thanks for your valuable reply and i tried to do that and getting following error
Completed | //Shell to Action Script Conversion Utility |
Completed | delete __appendfile |
Completed | appendfile /usr/seos/bin/selang -c ‘ru user unix’ |
Completed | //modify appendfile to allow execution |
Failed | wait chmod 555 "{(client folder of current site as string) & “/__appendfile”} |
//execute shell script as written | |
wait “{(client folder of current site as string) & “/__appendfile”}” |
I think you need a closing doublequote on the chmod command.
sorry, my bad, that line should be:
wait chmod 555 “{(client folder of current site as string) & “/__appendfile”}”
Thanks for your extended support.
unfortunately i am still getting failed with exit code NONE,
and if possible check for multiple used.
advanced thanks,
sandeep
