Hello,
We are using IBM Endpoint Manager v 9.1.1117.0
My problem is that I cannot log into my console and display any data. I get the standard “loading sites, X, Y, Z” screen that loads normally, and then it loads just the “frame” of the program. Resetting the console cache, using the uninstaller/cleaner utility… nothing fixes the problem. It worked just fine yesterday morning but then in the afternoon it stopped. I have 6 errors at the bottom bar which I have placed at the bottom of this.
This has been happening to other users for a long time but never mine. Now today it is doing it to me.
At 11/10/2015 4:11:12 PM
in site #9287 ‘BigFix Labs’
The following files had a checksum that did not match the checksum in
the site directory listing:
TWS 5000.fxf
At 11/10/2015 4:10:54 PM
in site #1 ‘BES Support’
EULA_Datacenter Management_9.2_SLV.html
EULA_IBM License Metric Tool_9.2_SLV.html
EULA_SmartCloud Patch Management_9.0_JPN.html
EULA_SmartCloud Patch Management_9.0_KOR.html
EULA_Software Use Analysis_9.0_CES.html
EULA_Software Use Analysis_9.2_notices.html
EULA_Starter Kit for Lifecycle Management_9.0_FRA.html
EULA_Starter Kit for Lifecycle Management_9.0_IND.html
At 11/10/2015 4:11:13 PM
in domain specification AllContent.BESDomain
File error “class DirectoryNotFoundError” on “C:
\Users\is00amm\AppData\Local\BigFix\Enterprise Console\10.1.1.185
\PLASTIPAK.COM_is00amm\Sites\BES Support\BESDomain_2_0.xsd”: Windows
Error 0x3: The system cannot find the path specified.
in site Enterprise Security
in domain specification PatchesForWindowsEnglishWebReports.BESDomain
class UnableToResolveReference
in site Updates for Windows Applications
in domain specification UpgradesForWindowsWebReports.BESDomain
in site Patching Support
in domain specification PTCH-SLE.BESDomain
