I have a custom property that is using the IF/THEN/ELSE statement. However, for one of the values I want it to look for 2 specific strings in the text document to qualify the response. For example:
IF exist lines whose (it as lowercase contains “Fully” as lowercase) of it AND exist lines whose (it as lowercase contains “Off” as lowercase) of it THEN “Suspended” ELSE …
It’s basically reading a text file that would have the word Fully on one line and Off on another. I want it to see both of these in the file, or move on
i may of misunderstood your requirements, but if you want to have a multiple IF THEN ELSE statement, here is what i would have:
IF ((IF exist lines whose (it as lowercase contains “Fully” as lowercase) of it AND exist lines whose (it as lowercase contains “Off” as lowercase) of it THEN “Suspended” ELSE “False”) of file “C:\testfile”) THEN … ELSE…
point to note for IF THEN ELSE statements is the output of THEN and ELSE need to be other the same type i.e string or it will give you the E: Incompatible types. error
