yes, I am saying the same thing"The download file is not the same file the script is trying to execute". I think BigFix Team need to correct this fixlet.
I know this is an old post, but figured I’d comment. This update was failing to download, more than likely a proxy server issue on our end even though the proxy admin said the download address was allowed. Anyway, I changed to the action script to point to http://download.windowsupdate instead of https://download.visualstudio, which I know is allowed through and I finally got it to work. Thought I’d post in case it helps someone else…you never know.
Which ones in particular ones are you referencing? The link from the fixlet mentioned by SmokyMTN appears to be correct to me. It’s valid and the checksum appears correct after I’ve downloaded it.
