MS15-124 - Not visible in BigFix Console
Hello All,
I do not see MS15-124 patch available in Bigfix. Is there any way to import it or we need to create a fixlet?
Please suggest!!
Superseded by MS16-001 for Windows 2008 R2.
The XP versions are no longer available from the Microsoft Download Center.
Check the supersedence int he Microsoft Update Catalog -
See https://www.catalog.update.microsoft.com/Search.aspx?q=MS15-124, click each link and look at the “Package Details” to see which updates superseded this one for any other OS/Browser combinations you have.
Thanks Jason for your quick response.
