MS13-083 possible false positive
IBM, can you investigate whether there is an issue with the relevance in the following Fixlet -
MS13-083: Vulnerability in Windows Common Control Library Could Allow Remote Code Execution - Windows 8 Gold / Windows Server 2012 Gold(x64)
Many Windows 2012 servers are failing to apply the patch, and when deploying through BigFix, the exit code returned is -2145124329** meaning the patch is not applicable to the OS.
I can only assume other customers are exhibiting a similar issue ??
Hi Nick,
Yes we have received similar reports about this issue. We are currently verifying the fix.
We will post an update here once we have updated the content.
Thank you!
just additional info from my environment - I got the same issue with fixlet MS13-083 applicable to Win2012 servers - failed to install with exit code -2145124329. I also ran windows update on one of Win2012 server to see if this KB2864058 would show up BUT did not see it. I hope IBM would fix this issue soon. Thanks!
Hi, changes for MS13-083 has been published to site Patches for Windows (English), version 2292. Please gather the latest site content.
Thank you!
