MS10-014 KB977290 issue - N/A except for DCs
http://www.microsoft.com/technet/security/bulletin/MS10-014.mspx
Per the FAQ on the bulletin:
I am running one of the platforms that are listed in the affected software table. Why am I not being offered the update?
The update will only be offered to systems on which the affected component is both installed and enabled. Systems not configured in the role of a domain controller contain the vulnerable component, but are not affected and will not be offered this update through Automatic Updates.
It would appear this patch is not applicable except on DCs where it should show up as an applicable patch. However, it is showing up in the console on all win servers - believe the fixlet shoud be re-written to check if device is a DC - all others servers should not be applicable.
