Trying to create a silent installed for MS project 2013 that will install and inject serial key. I was any to do it with 2010 unable to use the same command. Anyone out there have any luck? thanks
I know that in our current environment, it requires the installer and a sperate file that contains the key that the installer pulls from. This may help.
