I’m trying to uninstall Project 2010 and I already edit the config.xml file in the “PrjPro.WW” directory. This is the action script below I used but the status is stuck on “running”. Any ideas what I am doing wrong?
When I run manually on computer it uninstalls silently with no issues. I created a batch file which is “setup.exe /x PrjPro /config PrjPro.WW\config.xml” and I just run that command on machine.
When I package this on BigFix the status is still stuck on “running” status and never uninstalls.
