I have a script located on the root of C on each of the SQL cluster nodes, and when I try to take action from Bigfix to either drain, pullall or balance the clustered resources, nothing happens.
This is the Bigfix action:
waithidden powershell.exe -executionpolicy Bypass -command “C:\MoveClusRes.ps1 drain”
It works fine when I log on to the box execute the script with "powershell.exe -executionpolicy Bypass -command “C:\MoveClusRes.ps1 drain”, but doesn’t work when doing it through Bigfix. Any idea?
