I read up on using createfile/appendfile to create a file and then copy/move it to make it into a valid .vbs file and then using BigFix to run that file. However, I’ve been having issues using the copy/move commands to allow this to happen, each command normally errors out with Copy failed (0) or Move failed (2). I’m just starting out with Fixlet Authoring, so if its something small I apologize.
Here’s what I have:
createfile until __End
Const HKEY_LOCAL_MACHINE = &H80000002
strComputer = “.”
Set objRegistry = GetObject(“winmgmts:\” & strComputer & “\root\default:StdRegProv”)
This vbs edits the registry file - I know I can edit/add registry files in BigFix - but this edits the default key which I had issues figuring out how to do inside a .reg file, a batch file, etc, so I decided to use VBS. The script works great, I just need to know how to set it up in BigFix to push to my boxes.
Thanks alot for the help - I wasn’t sure you could do Default keys in BigFix; originally this was meant to be a vbscript anyways and then we decided to just push it to everyone in BigFix.
