(imported topic written by GinaW)
The IBM Mobile Device Management team is pleased to announce the release of Mobile Device Management 2.2 today.
New Major Features:
Enterproid Divide Integration Enhancements - You can now fully define and provision Divide policies through IEM for Mobile with our new Divide Policy Dashboard
Security Compliance Dashboard - Added a centralized view to help view and manage users who violate assigned security policies.
Refined UI for IBM Mobile Client for Apple iOS- Updated the iOS app to provide an easier, more streamlined view of recommended app list and messages.
Additional Changes:
- Optimized the MDM Navigation Domain. The Domain (and the BigFix console in general) should refresh much more quickly in deployments with large numbers of actions.
- Fixed Setup Dashboard issue that prevented configuring LDAP using LDAP group filter.
- Fixed Setup Dashboard issue where passwords with certain special characters could not be set.
- Fixed a Traveler Extender bug which prevented using the “Deny Email” fixlet
- Fixed an iOS Profile Wizard bug where editing a profile would produce faulty relevance
- Added fixlet to send message to Android devices.
- Added a global security polices section to the Android client’s security compliance screen
- Android WifI Policies wizard now allows space in SSID
- Fixed iOS app crash when recommending apps with non-standard version numbers
- App Management dashboard now allows you to create Tasks instead of actions
- Updated OS detection logic for Lotus Traveler. Should remove many “Unknown” OS entries
- Fixed various broken links, typos and translation issues.
Required Actions:
Upgrade your MDM components. Use the MDM Health Checks dashboard to view the components that are out of date.
Published Site Version:
Mobile Device Management, version 68
Release Notes:
http s:// www. ibm. com/ deve lope rwor ks/c ommu nity /wik is/h ome? lang =en# /wik i/Ti voli %20E ndpo int% 20Ma nage r/pa ge/R elea se%2 0Not e s
Documentation will be available on InfoCenter on 6/29/13.
