(imported topic written by GinaW)
IBM is pleased to announce the release of Enrollment and Extender Patch for Mobile Device Management:
Site Version 86
Release Features
Updated the Enrollment and Apple iOS Management Extender to replace a certificate that is due to expire on January 24th, 2014. This certificate impacts the IBM Endpoint Manager Mobile Client.
After the certificate expires, Recommended Apps and sending messages through the client will not function fully until the certificate is replaced.
Required Actions
Update all Enrollment and Apple iOS Management Extenders in your deployment by running the upgrade fixlet in Setup and Configuration > Manage Components > Upgrade MDM Components.
Extenders should be upgraded before January 24th, 2014 to avoid service disruption to Recommended Apps and the ability to send messages through the client. The update can be applied after the 24th if necessary.
Application Engineering Team
