MDT 3.1 issues
(imported topic written by pgill)
I don’t know if anyone has attempted to use the new MDT 3.1 or not yet, I can’t find any info on it. When ever I go to build a package using the MDT Bundle Creator v3.1.29, it processes, then it errors out on this:
[Wed May 1 14:03:21 2013] Creating Media item at L:\BigFixOSD\MDTBundle
<<<<< L:/MDTBundleCreator-3.1.29\bftemp.ps1 <<<<<
Add-PSSnapIn Microsoft.BDD.PSSnapIn -ErrorAction SilentlyContinue
New-PSDrive -Name “BFOSD” -PSProvider MDTProvider -Root “L:\BigFixOSD\DeploymentShare”
new-item -path “BFOSD:\Media” -enable “True” -Name “MEDIA001” -Comments “” -Root “L:\BigFixOSD\MDTBundle” -SelectionProfile “Everything” -SupportX86 “True” -SupportX64 “True” -GenerateISO “False” -ISOName “LiteTouchMedia.iso” -Verbose
new-PSDrive -Name “MEDIA001” -PSProvider “MDTProvider” -Root “L:\BigFixOSD\MDTBundle\Content\Deploy” -Description “BigFix OSD Media Item” -Force -Verbose
Start-Sleep -s 10
L:/MDTBundleCreator-3.1.29\bftemp.ps1 >>>>>
[Wed May 1 14:03:21 2013] start /WAIT /I C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -noninteractive -command “& ‘L:/MDTBundleCreator-3.1.29\bftemp.ps1’”
[Wed May 1 14:03:50 2013] Modifying Settings.xml…
[Wed May 1 14:03:50 2013] Updating Media. Please wait…
Update-MDTMedia -Path “BFOSD:\Media\MEDIA001” -Verbose
[Wed May 1 14:03:50 2013] start /WAIT /I C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -noninteractive -command “& ‘L:/MDTBundleCreator-3.1.29\bftemp.ps1’”
[Wed May 1 14:10:10 2013] Done!
[Wed May 1 14:10:10 2013] Introspection of PE wim files has commenced
[Wed May 1 14:10:10 2013] Using command: RBAGENT\rbagent64.exe -o rad-temmakewpe exportdir=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot” wpex86path=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\LiteTouchPE_x86.wim” wpeamd64path=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\LiteTouchPE_x64.wim” osdtoolsdir=“L:/MDTBundleCreator-3.1.29/RBAgent”
[Wed May 1 14:11:17 2013] exportdir: L:\BigFixOSD\MDTBundle\Content\Deploy\Boot
[Wed May 1 14:11:17 2013] ERROR: Error generating PE wim files. check L:/MDTBundleCreator-3.1.29/RBAgent\osdtools.log for more info
[Wed May 1 14:11:17 2013] Introspection of PE wim files has completed successfully
[Wed May 1 14:11:17 2013] Making directory: L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX86
[Wed May 1 14:11:17 2013] Making directory: L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX64
[Wed May 1 14:11:17 2013] Moving L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\WPE-x86.rad to L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX86\WPE-x86.rad
[Wed May 1 14:11:17 2013] ERROR: No such file or directory
[Wed May 1 14:11:17 2013] Error: Unable to cleanup and move Windows PE WIM archives: Died at /<L:\MDTBundleCreator-3.1.29\MDTBundleCreator64.exe>MDT/Introspect.pm line 144.
[Wed May 1 14:11:17 2013] ERROR: Media update failed 5 times. Check for any errors in the generated logfile. Make sure to run with Administrator privileges. Otherwise, try freeing up system resources and try again.
[Wed May 1 14:11:17 2013] ERROR: Bundle Creation encountered fatal error:
Died at CreateBundle.pl line 258.
So any assistance is appreicated.
This log L:/MDTBundleCreator-3.1.29/RBAgent\osdtools.log does not exist btws.
v/r
(imported comment written by JasonHonda)
We have seen issues similar to this before. First thing would be to try restarting your computer. If trying to run immediately after WADK and/or MDT 2012, issues like this can occur during the media generation process.
If that doesn’t resolve the issue, I would look into manually generating the media, which is what I believe to be failing. To do that, go in to MDT Deployment Workbench. Expand the BigFix OSD Deployment Share->Advanced Configuration->Media. Then right click on the MEDIA001 item and select “Update Media Content”. Depending on the error seen there, it might provide better insight. It could be a permissions or AV issue with using DISM or imagex.
(imported comment written by pgill)
So I tried a reboot of the system and got the same error message.
When I tried it through the workbench, I got: "Unable to mount the WIM, so the update process cannot continue. "
EDIT:
Turned off McAfee HBSS and got this message instead with the Update Media Content:
Copied standard folders.
Boot images updated.
Setting up dual x86/x64 boot image.
Not adding x86 boot entry to UEFI BCD because dual boot UEFI media is not supported.
Not modifying display order for dual boot UEFI.
Boot configuration editing completed.
Reset read-only attributes.
Skipped ISO generation.
When I try to import what was created into IEM, I get : “There was a problem compressing the file.”
Ok, good to see figuring out McAfee was blocking the use of image mounting tools, and so that got further.
I’m assuming that after that, you ran the MDTBundleCreator again, and it successfully built this time.
Now on upload of the MDT Bundle to the dashboard you see that error. We can take a look at a log file in %temp%\OSDeployment\TemporaryZipFile.log on the console computer.
We are attempting to zip up the folder you specified, but it appears the output file is not existing, which should be %temp%\OSDeployment\TemporaryZipFile.zip. I’d also double check that a file zip.exe can be found in that %temp%\OSDeployment directory.
With McAfee off, I got this error with the Bundle Creator:
[Thu May 2 08:51:15 2013] Creating Media item at L:\BigFixOSD\MDTBundle
[Thu May 2 08:51:38 2013] Modifying Settings.xml…
[Thu May 2 08:51:39 2013] Updating Media. Please wait…
[Thu May 2 08:58:11 2013] Done!
[Thu May 2 08:58:11 2013] Introspection of PE wim files has commenced
[Thu May 2 08:58:11 2013] Using command: RBAGENT\rbagent64.exe -o rad-temmakewpe exportdir=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot” wpex86path=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\LiteTouchPE_x86.wim” wpeamd64path=“L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\LiteTouchPE_x64.wim” osdtoolsdir=“L:/MDTBundleCreator-3.1.29/RBAgent”
[Thu May 2 08:59:17 2013] exportdir: L:\BigFixOSD\MDTBundle\Content\Deploy\Boot
[Thu May 2 08:59:17 2013] ERROR: Error generating PE wim files. check L:/MDTBundleCreator-3.1.29/RBAgent\osdtools.log for more info
[Thu May 2 08:59:17 2013] Introspection of PE wim files has completed successfully
[Thu May 2 08:59:17 2013] Making directory: L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX86
[Thu May 2 08:59:17 2013] Making directory: L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX64
[Thu May 2 08:59:17 2013] Moving L:\BigFixOSD\MDTBundle\Content\Deploy\Boot\WPE-x86.rad to L:\BigFixOSD\MDTBundle\Content\Deploy$OEM$\BigFixOSD\Boot\PEX86\WPE-x86.rad
[Thu May 2 08:59:17 2013] ERROR: No such file or directory
[Thu May 2 08:59:17 2013] Error: Unable to cleanup and move Windows PE WIM archives: Died at /<L:\MDTBundleCreator-3.1.29\MDTBundleCreator64.exe>MDT/Introspect.pm line 144.
[Thu May 2 08:59:17 2013] ERROR: Media update failed 5 times. Check for any errors in the generated logfile. Make sure to run with Administrator privileges. Otherwise, try freeing up system resources and try again.
[Thu May 2 08:59:17 2013] ERROR: Bundle Creation encountered fatal error:
With McAfee ON, I get this:
[Wed May 1 17:03:29 2013] Creating Media item at L:\BigFixOSD\MDTBundle
[Wed May 1 17:03:51 2013] Modifying Settings.xml…
[Wed May 1 17:03:51 2013] Updating Media. Please wait…
[Wed May 1 17:06:54 2013] ERROR: Media update failed (try 5/5)
[Wed May 1 17:06:54 2013] ERROR: Media update failed 5 times. Check for any errors in the generated logfile. Make sure to run with Administrator privileges. Otherwise, try freeing up system resources and try again.
[Wed May 1 17:06:54 2013] ERROR: Bundle Creation encountered fatal error:
zip error: Nothing to do! (try: zip -r -S C:\Users\xraygill\AppData\Local\Temp\2\OSDeployment\TemporaryZipFile.zip . -i .)
uploadmanager.exe, UploadManagerFiles folder, zip.exe and TemporaryZipFiles.log are all in that folder.
Ok, not sure why that failed to upload, but we’ll ignore that for now until we get the bundle created properly.
For that, look at L:/MDTBundleCreator-3.1.29/RBAgent\rbagent.log The output misidentifies the file to look at. This may provide some insight into why we were unable to process things properly.
[2013/05/02 08:58:11] IBM Tivoli Provisioning Manager for Images Web extension 64 bits v.7.1.1.12 (200.39)
[2013/05/02 08:58:11] Licensed Materials - Property of IBM. - INTERNAL
[2013/05/02 08:58:11] © Copyright IBM Corporation 1998, 2013.
[2013/05/02 08:58:11] All Rights Reserved. IBM, the IBM logo, and Tivoli are trademarks of IBM Corporation in the United States, other countries or both.
[2013/05/02 08:58:12] A Loading server extensions if available
[2013/05/02 08:58:12] A Working in offline, extensions are disabled
[2013/05/02 08:58:12] A No ServerID has been defined
[2013/05/02 08:58:12] A Creating offline WPE environmet…
[2013/05/02 08:58:12] A Looking for WinPE toolkit (ver=0)
[2013/05/02 08:58:12] [Progress] 1% done (Creating WinPE 4 engine for x86)
[2013/05/02 08:58:12] [Progress] 5% done (Base WinPE copied)
[2013/05/02 08:58:12] [Progress] 5% done (Mounting base WinPE)
[2013/05/02 08:58:12] A Running [“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe” /Mount-Wim /WimFile:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_A323D094BD9BE4E1_1\sources\boot.wim” /index:1 /MountDir:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1”]
[2013/05/02 08:58:24] A Command [“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe” /Mount-Wim /WimFile:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_A323D094BD9BE4E1_1\sources\boot.wim” /index:1 /MountDir:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1”] successfully completed in 11.26 seconds
[2013/05/02 08:58:39] A Running [reg load HKLM\h_sys C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1\windows\system32\config\system]
[2013/05/02 08:58:39] A Command [reg load HKLM\h_sys C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1\windows\system32\config\system] successfully completed in 0.24 seconds
[2013/05/02 08:58:40] A Running [reg unload HKLM\h_sys]
[2013/05/02 08:58:40] A Command [reg unload HKLM\h_sys] successfully completed in 0.28 seconds
[2013/05/02 08:58:40] [Progress] 10% done (Installing packages)
[2013/05/02 08:58:40] A Running [“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe” /Image:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1” /Add-Package /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup-client.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup-server.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-legacysetup.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-wmi.cab” /English]
[2013/05/02 08:59:17] A Command [“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe” /Image:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1” /Add-Package /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup-client.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-setup-server.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-legacysetup.cab” /PackagePath:“L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Windows Preinstallation Environment\x86\WinPE_OCs\winpe-wmi.cab” /English] failed with exit code 5 in 37.13 seconds
[2013/05/02 08:59:17] A Command error: Unknown error, Error when installing some packages in WinPE: Error code (5)
[2013/05/02 08:59:17] A Error raised by AddPackages in load.rbc, line 3931 [:0]
[2013/05/02 08:59:17] A Unknown error (Error when installing some packages in WinPE: Error code (5))
[2013/05/02 08:59:17] A (called from MakeWPESoftware (load.rbc:3939))
[2013/05/02 08:59:17] A (called from MakeWPE (load.rbc:4261))
[2013/05/02 08:59:17] A (called from RAD_temmakewpe (load.rbc:4330))
[2013/05/02 08:59:17] A (called from AgentDispatch (rbagent.rbc:4066))
[2013/05/02 08:59:17] A (called from --toplevel-- (rbagent.rbc:4297))
[2013/05/02 08:59:17] A RbAgent command rad-temmakewpe has failed [AGT:4073]
I’ll have to get some more team members involved to try and figure out this issue. Of course opening a support case will get some more traction than on the forum, but we of course try to help here.
The WinPE wim is likely still mounted. You can try running the command yourself that failed to see what kind of error output might be there.
Can you confirm the existence of some/all of the packages listed in that command which are being added to WinPE?
The cab files are definately there.
Last time I tried to open up a support case, they refered me to the forums for more support because they said that the engineers were on here more =D
When the command is run from an elevated command prompt I get:
Error 0xc1420127
The specified image in the specified wim is already mounted for read/write access.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
DISM.LOG
2013-05-02 15:00:06, Info DISM PID=7724 TID=4784 Scratch directory set to ‘C:\Users\xraygill\AppData\Local\Temp\2’. - CDISMManager::put_ScratchDir
2013-05-02 15:00:06, Info DISM PID=7724 TID=4784 DismCore.dll version: 6.2.9200.16384 - CDISMManager::FinalConstruct
2013-05-02 15:00:06, Info DISM PID=7724 TID=4784 Successfully loaded the ImageSession at “L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM” - CDISMManager::LoadLocalImageSession
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Manager: PID=7724 TID=4784 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2013-05-02 15:00:06, Info DISM DISM.EXE:
2013-05-02 15:00:06, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2013-05-02 15:00:06, Info DISM DISM.EXE: Host machine information: OS Version=6.1.7601, Running architecture=amd64, Number of processors=16
2013-05-02 15:00:06, Info DISM DISM.EXE: Dism.exe version: 6.2.9200.16384
2013-05-02 15:00:06, Info DISM DISM.EXE: Executing command line: “L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe” /Mount-Wim /WimFile:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_A323D094BD9BE4E1_1\sources\boot.wim” /index:1 /MountDir:“C:\Users\xraygill\AppData\Local\Temp\2\tpm_ED8656F64E67CB83_1”
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Loading Provider from location L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Connecting to the provider located at L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Loading Provider from location L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\WimProvider.dll - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Connecting to the provider located at L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Loading Provider from location L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Connecting to the provider located at L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Loading Provider from location L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Connecting to the provider located at L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Loading Provider from location L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Connecting to the provider located at L:\Program Files (x86)\Windows Kits\8.0\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2013-05-02 15:00:06, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: FolderManager
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: WimManager
2013-05-02 15:00:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: WimManager.
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: VHDManager
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericImagingManager
2013-05-02 15:00:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericImagingManager.
2013-05-02 15:00:06, Info DISM DISM.EXE: Attempting to add the commands from provider: Compatibility Manager
2013-05-02 15:00:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: Compatibility Manager.
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Getting Provider WimManager - CDISMProviderStore::GetProvider
[7724] Caller did not request sparse mount
[7724] [0x80070003] FIOGetFileId:(862): The system cannot find the path specified.
[7724] [0x80070003] FindOtherMountsForWimCallback:(392): The system cannot find the path specified.
[7724] [0x80070002] FIOGetFileId:(862): The system cannot find the file specified.
[7724] [0x80070002] FindOtherMountsForWimCallback:(392): The system cannot find the file specified.
[7724] ImageUnmarshallHandle: Reconstituting wim at C:\Users\xraygill\AppData\Local\Temp\2\tpm_A323D094BD9BE4E1_1\sources\boot.wim.
[7724] [0xc1420127] WIMMountImageHandle:(906)
[7724] [0x80070002] StateStoreRemoveMountedImage:(1041): The system cannot find the file specified.
[7724] [0x80070002] WIMMountImageHandle:(1116): The system cannot find the file specified.
2013-05-02 15:00:06, Error DISM DISM WIM Provider: PID=7724 TID=4784 Failed to mount the image. - CWimImageInfo::Mount(hr:0xc1420127)
2013-05-02 15:00:06, Error DISM DISM WIM Provider: PID=7724 TID=4784 base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:2411 - CWimManager::InternalOpMount(hr:0xc1420127)
2013-05-02 15:00:06, Error DISM DISM WIM Provider: PID=7724 TID=4784 base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:3682 - CWimManager::InternalCmdMount(hr:0xc1420127)
2013-05-02 15:00:06, Error DISM DISM WIM Provider: PID=7724 TID=4784 Error executing command - CWimManager::InternalExecuteCmd(hr:0xc1420127)
2013-05-02 15:00:06, Error DISM DISM WIM Provider: PID=7724 TID=4784 base\ntsetup\opktools\dism\providers\wimprovider\dll\wimmanager.cpp:1928 - CWimManager::ExecuteCmdLine(hr:0xc1420127)
2013-05-02 15:00:06, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2013-05-02 15:00:06, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Disconnecting Provider: Compatibility Manager - CDISMProviderStore::Internal_DisconnectProvider
2013-05-02 15:00:06, Info DISM DISM Provider Store: PID=7724 TID=4784 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
(imported comment written by francesco.latino)
Hi, I experienced the same problem with a colleague running the same scenario at customer site and it was the McAfee antivirus not completely disabled.
I would please ask you to retry doublechecking no AntiVirus (AV) process running.
This is what he just said to me: probably the McAfee Antivirus is still blocking access in some ways
we ran the the command manually for one package at a time and it came back with access denied.
At that point we also thought AV was off but it wasn’t - the security team just turned off access protection but write privileges was still not given to that directories.
so we asked security team to completely disable AV and stop running service and then we manually ran it again for the 1 package and it succeeded.
However when we kicked it off from the TEM console it failed again as the AV came on automatically after a while. I would suggest to doublecheck again that AV is absolutely down
I think this is what is causing the issue: may you please validate no AV running?
Running the same command should give access denied until completely stopped (and may be it will automatically restart after a while)
Other info on the Web:
http://social.technet.microsoft.com/Forums/en-US/mdt/thread/fbbc45f7-9d21-4e29-a154-c85486bef856
I think you might be right:
5/2/2013 2:21:12 PM Would be blocked by Access Protection rule (rule is currently not enforced) ------\xraygill C:\Windows\Explorer.EXE C:\Users\xraygill\AppData\Local\Temp\2\OSDeployment\uploadmanager.exe Common Standard Protection:Prevent common programs from running files from the Temp folder Action blocked : Execute
5/2/2013 2:21:12 PM Would be blocked by Access Protection rule (rule is currently not enforced) ------\xraygill C:\Windows\Explorer.EXE C:\Users\xraygill\AppData\Local\Temp\2\OSDeployment\zip.exe Common Standard Protection:Prevent common programs from running files from the Temp folder Action blocked : Execute
Good ! Hope this will now fix the flow.
Let us know if still getting issues…
Yea, no, not the issue.
means that it would have been blocked, but it is not.
DISM is giving me errors though:
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SOFTWARE
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SOFTWARE, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SYSTEM
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SYSTEM, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SECURITY
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SECURITY, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SAM
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/SAM, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/COMPONENTS
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/COMPONENTS, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/DEFAULT
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/System32/config/DEFAULT, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Users/default/ntuser.dat
2013-05-03 12:21:59, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Users/default/ntuser.dat, the client may still need it open. [HRESULT = 0x80070005 - E_ACCESSDENIED]
2013-05-03 12:21:59, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Users/xraygill/AppData/Local/Temp/2/tpm_C7A9D1B12E8EB957_1/Windows/system32/smi/store/Machine/schema.dat
I still might question whether or not McAfee is still causing issues. Even if it says it’s not causing issues, or that it’s turned off, we commonly see it still having an impact, so I would very strongly recommend fully circumventing those security tools at least for this test. That is what most searches for the latest errors still point to.
At this point due to failed attempts, I might also recommend cleaning up past mounted WIMs.
dism /Get-MountedWimInfo
dism /Unmount-Wim /MountDir:c:\whateveryousawfromlastcommand /discard
And manually retry dism command: I expect it to fail independetly from our code
If you manually play with Dism, did you get similar failure ?
When I run even the “
” command all I get is:
Deployment Image Servicing and Mangement tool
Version: 6.1.7600.16385
_
And that is it.
EDIT:
After a while it times out with: This application has requested the Runtime to terminate it in an unusal way.
With a pop up box for ServerAgentManager.exe : Application has generated an exception that could not be handled.
(imported comment written by IanRobertson)
I ran into this problem yesterday and found some compound problems. One is a Tivoli bug, the other is an AV/Microsoft issue (McAfee in my case). Both are independent but can contribute to the problem.
The most easily observed symptom is that the use of mdtbundlecreator fails. Depending upon how much deeper you dig into the various logs, you’ll find lots of other errors. Let me simplify this all and say if you encounter any errors running this tool, check and fix the items below.
The first problem I found was with the RBAgent utility and how it uses an environment variable. The RBAgent utility, which is called by one of the scripts that is part of mdtbundlecreator, is passed a command line which includes the environment variable %temp%. This variable points to the current user’s temporary directory. Normally this is something like “c:\users<username>\AppData\Local\Temp”. The problem comes in when the username exceeds 8 characters, because then Windows has that named “c:\users\userna~1\AppData\Local\Temp”. When it’s processed by the command line into RBAgent, it replaces the tilde character with a space, so it actually looks like “c:\users\userna 1\AppData\Local\Temp”. That directory is invalid, and it fails.
To check for this condition, type “echo %temp%” at the command line and see if it includes the tilde character. If it does, then before you run the utility, reset this variable by typing “set temp=c:\users<full username>\AppData\Local\Temp”. After you do this you will need to run mdtbundlecreator from the same command-line window.
The second issue I found was with McAfee’s access protection. There are reports above here that talk about logs saying “would be blocked, but it isn’t”, but this issue has nothing to do with that, it’s a separate McAfee/AV issue. Essentially it boils down to a check that McAfee does to a really broken Windows API call that Microsoft can’t fix (or it will break a bunch of stuff). The solution is to temporarily disable Access Protection in McAfee (or any other AV product that does a similar check) when you run mdtbundlecreator. And as another commenter reported, this will re-enable itself, so make sure it is disabled for the entire time that you are running the utility. More information can be found at these two URLs:
https://kc.mcafee.com/corporate/index?page=content&id=KB76867&actp=LIST
https://kc.mcafee.com/corporate/index?page=content&id=KB52204
I hope this is helpful for those who are trying to use this feature and are pulling out their hair!
(imported comment written by sergio.tarchi)
in my environment I use the Administrator user to create the MDT bundle and the temp directory is the following:
C:\Users\Administrator\Desktop\MDTBundleCreator-3.2.20>echo %temp%
C:\Users\ADMINI~1\AppData\Local\Temp
I launched the creation from the desktop
C:\Users\Administrator\Desktop\MDTBundleCreator-3.2.20>MDTBundleCreator.exe
and in parameters.ini I have
target=C:\Users\Administrator\Desktop\BigFixOSD
but I’m able to successfully build an MDT bundle 3.2.20
Do you see any difference from your environment? Could you please attach logs (setup.log file in the MDT bundle creatore folder)?
Thanks.
Sergio,
I can save you some time and tell you that what I observed is the output from the RBAgent utility shows a space in the filepath where the tilde character is. When it tries to read the file in that directory, the path is wrong and it fails. Review the code for the RBAgent utility and I believe you’ll find a bug there.
Ian
Hi. Thanks. It would be useful to be able to reproduce the error condition to know which is the code part to review and where that output has been originated from. Would it be possible for you to collect the log file and compare the conditions where the error occurred?
Thanks.
