https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-266 |
Signature request Aperture and Hailstorm (*nix platform) |
Inventory |
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-265 |
Support for the distributed VM Manager Tool on Ubuntu |
Inventory |
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-264 |
Add detailed component version to Oracle Database reports |
Inventory |
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-263 |
‘VERITAS InfoScale Enterprise’ version 7.3 software not detected on windows servers. kindly include this in catalog |
Inventory |
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-262 |
Ability to hide the ‘To Do’ list from non-administrators in BFI |
Inventory |
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-155 |
Ability to prevent remote user input on BigFix Remote Control sessions |
Lifecycle |
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-154 |
Allow for scheduled activities within webreports for certain days of the week M & F or MWF rather than every X days. |
Lifecycle |
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-153 |
Be able to resubmit a automation plan step |
Lifecycle |
https://bigfix-ideas.hcltechsw.com/ideas/BFMCM-I-13 |
MDM doesn’t support multiple BASE_DN |
Modern Client Management |
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-231 |
Patching Policies Add Defender and Malicious Software Removal Tool |
Patch |
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-230 |
Ceph patches for RHEL |
Patch |
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-229 |
Ability to “Tag” fixlets so REST API automation can add them to Baelines based on Tags |
Patch |
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-228 |
Edge Update automatic update management task |
Patch |
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-227 |
Integration of Big Fix Patch with Qradar |
Patch |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-312 |
Integrating Azure AD to BigFix |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-311 |
New User Preference: ability to define preference for “show non-relevant content” |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-310 |
Ability to easily report on Lock-Exempt Actions |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-309 |
UEFI Inspector Support on Linux |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-308 |
Relevance Inspector to Run PowerShell Queries |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-307 |
Overview evaluation intervals for analysis properties |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-306 |
BigFix Client Configurable AD Cache Persistence/Time |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-305 |
Per-site evaluation interval override |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-304 |
Update the algorithm that evaluates the conditions/filter of Server Based Computer Groups. |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-303 |
Request to throttle/prioritize API calls per source |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-302 |
Ability to disable a BigFix Operator if they haven’t logged in within a configurable amount of time |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-301 |
Relevance Inspector for YAML |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-300 |
Support Action Script Parameters in Fixlet Debugger |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-299 |
Add ldap-login URL endpoints to Web Reports and REST APIs |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/CON-I-11 |
Webreport “only if not empty” |
Platform |
https://bigfix-ideas.hcltechsw.com/ideas/CON-I-10 |
Last modified date as property in console |
Platform |
