For those that might not be aware, BigFix has an Ideas Portal to enable improved collaboration with our customers and partners around potential new features and capabilities to BigFix Product.
Below, please find the Ideas created in the Ideas Portal for the month of March 2021 for your reference. You can view their details, as well as vote or provide comments to those that interest you and your organization.
We will work to provide similar references here on the BigFix Forum in this Ideas category on a monthly basis for awareness and to foster additional collaboration.
Don’t have an account? It’s easy to sign up @ https://bigfix-ideas.hcltechsw.com/portal_users/new.
Thank you!
| URL | Idea name | Workspace name |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-18 | Add ability to do VM Manager type functions on AWS, Google, Azure etc cloud systems | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-100 | BigFix Remote Peer to Peer Session If Target System Lock Need to Alert Controller Administrator | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-181 | The BESAudittrail Cleaner does not remove orphaned properties unless they are a single analysis. If an analysis contains multiple properties we would like to be able to delete any properties orphaned within an analysis. | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-180 | The BESAudittrail Cleaner only identifies and removes custom content. We need to do the same for external properties as well. | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-153 | Patch support for Microsoft .NET Framework 5x | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-99 | Web Reports filter “is one of” and provide a list (one item per line) in a text box | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-152 | Break up Patches for Windows into multiple sites | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-179 | Relay Affiliation use case for Internet-Facing Relays to not use hop counts | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-178 | Client Uninstall/Service Stop Protection | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-199 | Analysis to detect OS misconfigurations that could prevent proper scans | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-198 | Software Signature Addition Request | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-177 | FourEyesAuthentication needs to support SAML style authentication | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-17 | Azure Cloud Plugin Proxy Support | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-176 | Persistent connection for relays | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-151 | Enhance log file records with date/time stamps | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-197 | Allow centralized VM Manager Scanner to run on any BFI Datasource | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFES-I-9 | Scheduled agent installation CDT. | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-196 | Signature for Splunk Universal Forwarder for Linux (6.x and 7.x) | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-175 | Agent 10 published in reverse order | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-16 | Cloud Plugin support for Oracle Cloud Compute | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-174 | BESClient UI or Self-Service Application for Linux | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-195 | We have the only EOS(End of Support) colum in Bigfix Inventory. We required EEOS(Extended End Of Support) dates should be included in the BFI report colum | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-194 | Aix Operating system only shows the version. we required the TL levels with Fix pack details on BfI | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-15 | Allow Ability to generate filtering conditions for the CloudAPI endpoints to be retrieved by the plugins | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-173 | Add ETL Scheduler App to WebUI | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-98 | BigFix Remote Target should reject request if Users system is locked | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-172 | Add Start/End Time to computer Action History view | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-171 | Search Action Script and Relevance (both fixlets and tasks) | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-193 | There is no installation date for software on the machine. | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-170 | WebReports Users - last login date | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-192 | Some catalog missing for big vendor. | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-76 | Saved Reports Enhancement | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-150 | Add Patching Support subfolder to Dashboards main folder in All Content | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-169 | Ability to restrict fallback to HTTP for VMWare mgmt extender and plug-ins | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-149 | Add better filters to WebUI | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-191 | Signature for CA Privileged Access Manager | Inventory |
