(imported topic written by wnolan91)
Not sure if this should go under the BES Customizations or Feature Request, as one is a bug and the other a Feature Request…
When trying to add a Category, and you select “New SubCatagory” there is no option for a Higher level. To get around this you must modify the name. For example.
If we want to categorize the HARDWARE Properties we need to modify the name RAM to Hardware::RAM
Here in lies the Feature Request: Retrieved Properties which are created by Reserved, you cannot modify the name to put it in a Category, making it difficult to categorize Retrieved Properties in a complete way.
