Looking to use the BitLocker Management portion but can’t find any documentation on it. Could anyone point me in the right direction?
Where did you see the info about BitLocker to begin with?
Under BigFix Labs, go to the Sites tab, then theres an option to enable/disable BitLocker Management.
If its already on, there should be a folder on the left side for BitLocker in BigFix Labs
