(imported comment written by SamuelMak)
Hello Tim,
I did play around with the upload maintenance settings and tried restarting everything.
I guess the most significant change was the deletion of temp file.
Hello Tim,
See now I am having a problem similar to SamuelMak.
Image uploaded overnight, the temp folder was empty, but I have the yellow triangle with the “file upload in progress”
I tried it again this morning, watched the temp folder grow to the size of the image and then disappear.
I can see the WIM file sitting in
\Server\L$\Program Files (x86)\BigFix Enterprise\BES Server\wwwrootbes\Uploads\FA6F58B74E56AE2DCCA6AC88B7E18D354B4436C2\Win7x64_Test.WIM.BFOSD
But I cannot deploy it because it does not think it is fully uploaded.
SIDE NOTE: Is there a way to have these BFOSD files be stored somewhere else. My L$ drive is only 80 static GB. I made an R$ Drive that is 250 Dynamic GB that I have the image captured to.
Hi Pgill,
So your image doesn’t appear in “re-image” dashboard?
i didn’t notice my uploads folder, however can you check the downloads\sha1 folder for the file?
you should find something of that wim size.
Also, do check the logs folder, the fact that the file disappeared, it should have gone somewhere.
I can check it again when i’m back in office tomorrow afternoon.
Regards,
Samuel Mak
Samuel,
My issue is that the WIM file does show up where it is supposed to in \Server\L$\Program Files (x86)\BigFix Enterprise\BES Server\wwwrootbes\Uploads\FA6F58B74E56AE2DCCA6AC88B7E18D354B4436C2\Win7x64_Test.WIM.BFOSD after it disappears from the TEMP folder, but they yellow triangle never goes away and because of this, I cannot re-image because it still thinks it is uploading and no available for reimage. No where else besides the capture folder have the WIM.
(imported comment written by JasonHonda)
Have you checked the health checks dashboard to see that everything is passing. The most likely culprit is that the Upload Maintenance Service is not set up or not set up for OSD. This is what runs on the server and monitors uploaded files, and what the dashboard is checking with to verify the upload is ready to be used.
Yup. Everything is green.
However, when looking into it, I am missing the BFS.exe file and cannot start the plugin service.
Figured it out. The MFS.exe file was missing. I couldn’t remove the service, I couldn’t reinstall the service.
So I wrote a custom action script to do it without relevance.
prefetch MFS.exe sha1:b5d25a78b962776a895dedb4d2e626ec75201461 size:393216 http:
//software.bigfix.com/download/bes/util/mfs-1.0.0.11.exe delete __createfile delete move.bat createfile until _end_ @ECHO OFF mkdir
"{ value "EnterpriseServerFolder
" of key "HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server
" of registry as string & "Applications
" }" > NUL 2>NUL move
"{pathname of client folder of current site & "\__Download\MFS.exe
"{value "EnterpriseServerFolder
" of registry as string & "Applications\MFS.exe
"}" > NUL 2>NUL _end_ move __createfile move.bat wait
"{pathname of client folder of site "BESSupport
" & "\RunQuiet.exe
"}" move.bat waithidden
" }" -install waithidden
" }" -start regset
"[HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\BESReports]"
"WRHTTP"=
This forced it back in there after the Fixlets failed.
So I am not having much luck with this
Currently I have a 40GB (C:), 80GB (L:) and 250GB (R:)
BigFix is installed on the L:, Images are captured to the (R:)
So why is C: filling up when I attempt to push and image, as well as L:?
(imported comment written by kevin_friedheim)
Hi pgill,
We have opened an enhancement bug to resolve future issues around the Master Framework Service (MFS.exe) not running when it should be… Thanks.
In regards to your issues with C:\ growing - we utilize temporary scratch space on the windows drive when uploading and/or manipulating files that are to be uploaded. This is why you may see some fluctuation on your C:.
I called the IBM Helpdesk and they were unsure of how to answer this question. Since this keeps filling up my 40GB C: drive attempting to deploy a 24.5GB image, is there a way to have the scratch drive be somewhere else? I have an 80GB drive, that has the TEM server installed on it, and that has 35GB free with the image sitting on it and I also created a 250GB R: drive for using as storage and scratch. I would perfer to have stuff uploaded to the R: drive instead of the C: or L:.
Is there an easy way to accomplish this without rebuilding the server?
The first thing to note is that your image appears to be extremely large. 24GB definitely sets of red flags in my head that something is not right, or way too much stuff was included in the reference system. Simple Windows 7 images are maybe 3-5 GB after compressed in a WIM. In general, you may want to look into what was included, software/data, and not include in your vanilla image, and load the software and data on to the system after it has been imaged.
The second thing to note is if you plan on doing OS Deployment, a lot of setup and configuration considerations should be taken into account when setting up your server. Storing and deploying large images, especially 24GB in size, is a large strain on the server. There should definitely be adequate space on all drives that will be affected, not to mention performance so that regular server functions are not affected while serving up these large files. There are many configuration options that experts in deployment can help with. You can set things up so that the wwwrootbes directory exists on a separate drive, but I’m not sure how to configure after the fact. Also, if certain protocols are being used on your machine, downloads will be cached in the Temporary Internet Files folder which in your case is probably on C:. Proper cache settings on servers and relays need to be adjusted based on expected load, etc.
JasonHonda,
The way that we currently do things is with a Thick image. We have 1 image for the 2000+ machines we have here so that we do not have to have the helpdesk install new software on the fly when an instuctor randomly decides to change rooms and complains that the room does not have the software they need on it and they need is ASAP or else they cannot do training. Thus over time, what used to be a Thin, Medium, and Thick image has become one Thick image.
When I first set up the server, OSD was not a priority. Now we are looking at getting rid of Ghost and Ghost PXE and moving into TEMOSD and TPMfOSD.
Our problem with the thick image is that helpdesk wants to have more stuff in the image to do less work, the main reason I as as SysAdmin have been moving on the OSD is because then they have less touch time with the systems.
So that is where I am at. Trying to not rebuild the system, while moving forward.
A 24GB WIM is gigantic. Have you considered software distribution (see http://pic.dhe.ibm.com/infocenter/tivihelp/v26r1/topic/com.ibm.tem.doc_8.2/SWD_Users_Guide_PDF.pdf)?
If you insist on using the 24GB wim, you will need to adjust your environment - as Jason has recommended.
So I rebuilt everything on a physical box. Now I have gotten back to the point of uploading images, but I have again ran into this Yellow Triangle telling me “File uploads in process” I have removed, replace, upgrade, updated anything that had to do with MFS, UploadManger, UploadMaintenanceService, etc. The image shows up in temp, grows to proper size, and moves to the hashed folder in uploads with no issue, but this triangle will not go away and I cannot reimage because of it.
Suggestions?
This is from the OSD_UMS.log file
Fri, 10 Aug 2012 13:45:09 -0400
Could not connect to DSN: bes_bfenterpriseusing username: -sapassword
Cannot execute query:select count(1) from dbo.dashboarddata where name=‘OSD_Orphan_1321F80158D993B02C82B9F3A552B6BDD6AD63F4’ and IsDeleted=0 and DashboardId=‘OSDeployment.ojo’ to check if that deleted file has an orphan.
Waiting 10 seconds to retry the Temp to Uploads queue due to SQL failure.
Fri, 10 Aug 2012 13:45:17 -0400
Error in executing query to find 100 File Pointers with value 0: select top 100 newid() as row, name from dbo.dashboarddata where name like ‘OSD_FilePointer_%’ and convert(int, convert(varchar, convert(varbinary, value) ) ) < 1 and IsDeleted=0 and DashboardId=‘OSDeployment.ojo’ order by row
Error in executing query to find 100 orphan pointers: select top 100 newid() as row, name from dbo.dashboarddata where name like ‘OSD_Orphan_%’ and IsDeleted=0 and DashboardId=‘OSDeployment.ojo’ order by row
Fri, 10 Aug 2012 13:45:19 -0400
Fri, 10 Aug 2012 13:45:29 -0400
Our SQL Database is hosted on a seperate server running SQL 2008 R2
Your Upload Maintenance Service and Plugin Service is probably not set up properly to work with a remote database. The fixlets that set them up should have more information, but this KB may help.
JasonHonda, awesome as always. That seems to be it.
Now if I can get TPMfOSD figured out, I will be in good shape. I got it installed using TEM, but I have no idea what to do after that.
Everything is a step at a time here. Hopefully my problems help someone else.
I got the OS to deploy, and once it did, it looks like it rejoined the domain with no issue. But once it went to boot back into Windows to run the after OOBE it told me the password was incorrect (to the admin account) and then I get an error from LiteTouch about reinserting media, but the unit is still connected to the network. I have attached logs.
Thanks for the help.
Where did the wim file that you are deploying come from? Was it from our capture process? A quick search found this thread which appears to be similar to your case.
Can you mount and take a look inside the WIM with imagex and see if the directory in question is there c:\minint.
