I have been asking for this request ever since the first update came out and broke the first version of Bigfix. I would like a change to make the Location By Subnet, the Edit settings - stay static. I have over 200 subnets and it gets real old after a while to have to right-click on Location by Subnet and go to edit range settings everytime I am looking for something.
I am new to using the Location Property Wizard and could use some guidance. I came across the Kbase article below but it refers to version 5.0 (not sure if this still applies to version 6).
Basically, I would like to import a text file of subnets and corresponding locations, but it looks like the wizard is expecting a relevance expression. What’s the easiest way to setup this location property? Ideally, it would be great to just specify a subnet range even for each physical building/location, which would require less maintenance to keep up on the large list of subnets we have.
For what it’s worth, I tried using URL above anyway to export but I get an “XML parsing error” in the BES console when I try to import the computer property. I assume this URL/tool is not be valid for version 6?
That web page is no longer necessary (if you have BES 5.1+). Now the location property can easily be created inside the console by using the “Location Property Wizard” in your “Wizards” menu. It will let you copy from a file and then each client will identify the building it is in based on the subnet.
If you have more questions about the wizard, do you mind starting up a thread in the “BES Deployment” forum (more on-topic in that forum)?
