system
November 19, 2008, 6:12pm
1
(imported topic written by rharmer91)
I’m looking for the HP “Part Number” to pull into BigFix. I used WMI Explorer and couldn’t find it, I searched the net with HP “part number” +wmi and found some other people looking for the same information.
It should look like GV635AW#ABA
Help?
Thanks,
Rich
leewei
November 24, 2008, 11:55pm
2
Hi Rich,
I don’t have an HP system. However, I will take a few educated guesses, and hopefully they might be of some use.
It looks like HP has a Client Management Interface (http://h20331.www2.hp.com/Hpsub/cache/284014-0-0-225-121.html ) that has abstracted some hardware information and exposed as WMI.
In browsing their docs (http://h20331.www2.hp.com/Hpsub/cache/284408-0-0-225-121.html ), I think you can try the following.
selects “* from HP_BIOSString” of wmi “/root/HP/InstrumentedBIOS”
This assumes that the Client Management Interface is installed.
That I got the name space correct “/root/HP/InstrumentedBIOS”
If so, you should get a bunch of properties, and you can then easily extract the relevant info.
These other classes look interesting.
select * from HP_BIOSSetting
select * from HP_BIOSString
select * from HP_BIOSInteger
select * from HP_BIOSEnumeration
select * from HP_BIOSOrderedList
select * from HP_BIOSPassword
Lee Wei
system
November 25, 2008, 12:29am
3
(imported comment written by rharmer91)
In WMI explorer, I don’t have anything that is HP_, just CIM_. I don’t see anything in the CIM_BIOSXXX that has this detail in it. Very strange that this is hard. Another product we use (Zenworks Asset Manager) is pulling out the product number… I’ll have to find out how they do it.
Thanks for the ideas.
Rich
leewei
November 25, 2008, 12:45am
4
I should have asked what a Part Number is.
Could it be one of the following?
select “IdentifyingNumber from Win32_ComputerSystemProduct” of wmi
select “SerialNumber from Win32_BIOS” of wmi
select “SerialNumber from Win32_BaseBoard” of wmi
