How can i list/find out all the installed/fixed patches that is in my clients in patch management?
What are the steps?
What are the steps?
(imported comment written by sylviabeing)
In BES console, if you explore the “Actions” folder, you can find all deployment actions you have taken.
Under “Computers” folder, every client machine has a profile and there is an “Action History” Tab, all installed patches are listed here.
See the attached images for reference.
I found this previously but this is not the result i wanted. What i was looking for is a list showing all the patches and updates that is in the client PC alone.
Example: All windows update (Not only the ones fixed by me (Administrator), however it includes those that are installed by the user themselves.
Therefore, i would need have a list showing all updates in regardless it being updated by me using ‘Tivoli Endpoint Manager’ or be it the updated by the client themselves. I am looking for the list that can show me programs patches that are non-windows related as well like flash, java versions. Is there a way to list that out?
If you want a full list of updates installed on the client PC, you may have to create custom analysis to scan the client PC.
(imported comment written by ncpete)
May I suggest you create a task that runs on the targets and outputs the installed windows patch info to a file You can then read the contents of the file in by using an analysis. The task is attached. I hope this helps.
hello:
your task-List all installed patches has some extra file1.I use this to report.How can I delete file1 and remove the line 2 of the txt.
