(imported comment written by chenbr91)
Brolly…
The server below is a LS20 from IBM. The relevance above works on HP blades as they are HP nics and they display as gigbit adaptors in the registry key.
LS20 Reg Export of hklm\System\Currentcontrolset\Control\Class{4D36E972-E325-11CE-BFC1-08002be10318
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}
“Class”=“Net”
@=“Network adapters”
“EnumPropPages32”=“NetCfgx.dll,NetPropPageProvider”
“Icon”="-5"
“Installer32”=“NetCfgx.dll,NetClassInstaller”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0000\Linkage
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,35,00,34,\
00,43,00,37,00,44,00,31,00,34,00,30,00,2d,00,30,00,39,00,45,00,46,00,2d,00,\
31,00,31,00,44,00,31,00,2d,00,42,00,32,00,35,00,41,00,2d,00,46,00,35,00,46,\
00,45,00,36,00,32,00,37,00,45,00,44,00,39,00,35,00,45,00,7d,00,00,00,00,00
“Bind”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,35,00,34,\
“UpperBind”=hex(7):54,00,63,00,70,00,69,00,70,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001
“TxPacketDescCnt”=“200”
“RxStdDescCnt”=“200”
“RxCoalescingTicks”=“10”
“TxCoalescingTicks”=“30”
“RxMaxCoalescedFrames”=“5”
“TxMaxCoalescedFrames”=“200”
“Characteristics”=dword:00000084
“BusType”=“5”
“ComponentId”=“pci\ven_14e4&dev_16a8”
“Enable8021p”=“0”
“FlowControlCap”=“2147483648”
“LargeSendOffload”=“1”
“RxMtu”=“1500”
“TaskOffloadCap”=“63”
“InfPath”=“oem2.inf”
“InfSection”=“BCM5704S.XPInst”
“InfSectionExt”=".NTx86"
“ProviderName”=“Broadcom”
“DriverDateData”=hex:00,40,23,71,78,93,c3,01
“DriverDate”=“10-16-2003”
“DriverVersion”=“7.33.0.0”
“MatchingDeviceId”=“pci\ven_14e4&dev_16a8”
“DriverDesc”=“Broadcom NetXtreme Gigabit Fiber”
“NetCfgInstanceId”="{D4DDBF4F-89B8-4476-B02B-7BDF6D0AEDC5}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Linkage
“RootDevice”=hex(7):7b,00,44,00,34,00,44,00,44,00,42,00,46,00,34,00,46,00,2d,\
00,38,00,39,00,42,00,38,00,2d,00,34,00,34,00,37,00,36,00,2d,00,42,00,30,00,\
32,00,42,00,2d,00,37,00,42,00,44,00,46,00,36,00,44,00,30,00,41,00,45,00,44,\
00,43,00,35,00,7d,00,00,00,00,00
“UpperBind”=hex(7):52,00,61,00,73,00,50,00,70,00,70,00,6f,00,65,00,00,00,4e,00,\
64,00,69,00,73,00,75,00,69,00,6f,00,00,00,4e,00,4d,00,00,00,54,00,63,00,70,\
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,44,00,34,\
00,44,00,44,00,42,00,46,00,34,00,46,00,2d,00,38,00,39,00,42,00,38,00,2d,00,\
34,00,34,00,37,00,36,00,2d,00,42,00,30,00,32,00,42,00,2d,00,37,00,42,00,44,\
00,46,00,36,00,44,00,30,00,41,00,45,00,44,00,43,00,35,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi
“Service”=“b57w2k”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Interfaces
“UpperRange”=“ndis5”
“LowerRange”=“ethernet”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\Enable8021p
“ParamDesc”=“802.1p QOS”
“default”=“0”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\Enable8021p\enum
“0”=“Disable”
“1”=“Enable”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\FlowControlCap
“ParamDesc”=“Flow Control”
“default”=“2147483648”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\FlowControlCap\enum
“0”=“Disable”
“1”=“Rx PAUSE”
“2”=“Tx PAUSE”
“3”=“Rx/Tx PAUSE”
“2147483648”=“Auto”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\LargeSendOffload
“ParamDesc”=“Large Send Offload”
“default”=“1”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\LargeSendOffload\enum
“0”=“Disable”
“1”=“Enable”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\NetworkAddress
“ParamDesc”=“Locally Administered Address”
“Default”=""
“type”=“edit”
“LimitText”=“12”
“UpperCase”=“1”
“optional”=“1”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\RxMtu
“ParamDesc”=“Jumbo Mtu”
“default”=“1500”
“type”=“dword”
“min”=“1500”
“max”=“9000”
“step”=“500”
“base”=“10”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\TaskOffloadCap
“ParamDesc”=“Checksum Offload”
“default”=“63”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001\Ndi\Params\TaskOffloadCap\enum
“0”=“None”
“42”=“Rx TCP/IP Checksum”
“21”=“Tx TCP/IP Checksum”
“63”=“Tx/Rx TCP/IP Checksum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002
“BusType”=“5”
“Enable8021p”=“0”
“RxMtu”=“1500”
“NetCfgInstanceId”="{E3FE18C9-7CDD-4ED8-A4F8-948C54C9BA33}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Linkage
“RootDevice”=hex(7):7b,00,45,00,33,00,46,00,45,00,31,00,38,00,43,00,39,00,2d,\
00,37,00,43,00,44,00,44,00,2d,00,34,00,45,00,44,00,38,00,2d,00,41,00,34,00,\
46,00,38,00,2d,00,39,00,34,00,38,00,43,00,35,00,34,00,43,00,39,00,42,00,41,\
00,33,00,33,00,7d,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,45,00,33,\
00,46,00,45,00,31,00,38,00,43,00,39,00,2d,00,37,00,43,00,44,00,44,00,2d,00,\
34,00,45,00,44,00,38,00,2d,00,41,00,34,00,46,00,38,00,2d,00,39,00,34,00,38,\
00,43,00,35,00,34,00,43,00,39,00,42,00,41,00,33,00,33,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi
“Service”=“b57w2k”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\Enable8021p
“default”=“0”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\Enable8021p\enum
“0”=“Disable”
“1”=“Enable”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\FlowControlCap
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\FlowControlCap\enum
“0”=“Disable”
“1”=“Rx PAUSE”
“2”=“Tx PAUSE”
“3”=“Rx/Tx PAUSE”
“2147483648”=“Auto”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\LargeSendOffload
“default”=“1”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\LargeSendOffload\enum
“0”=“Disable”
“1”=“Enable”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\NetworkAddress
“Default”=""
“type”=“edit”
“LimitText”=“12”
“UpperCase”=“1”
“optional”=“1”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\RxMtu
“default”=“1500”
“type”=“dword”
“min”=“1500”
“max”=“9000”
“step”=“500”
“base”=“10”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\TaskOffloadCap
“default”=“63”
“type”=“enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002\Ndi\Params\TaskOffloadCap\enum
“0”=“None”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0003
“PnPCapabilities”=dword:00000001
“Characteristics”=dword:0000002a
“ComponentId”=“sw{eeab7790-c514-11d1-b42b-00805fc1270e}”
“InfPath”=“netrasa.inf”
“InfSection”=“Ndi-Mp-AsyncMac”
“ProviderName”=“Microsoft”
“DriverDateData”=hex:00,40,2a,7c,dd,68,c2,01
“DriverDate”=“10-1-2002”
“DriverVersion”=“5.2.3790.0”
“MatchingDeviceId”=“sw{eeab7790-c514-11d1-b42b-00805fc1270e}”
“DriverDesc”=“RAS Async Adapter”
“NetCfgInstanceId”="{1C6ABF84-7380-4B60-A142-3BC8728B97A7}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0003\Linkage
“RootDevice”=hex(7):7b,00,31,00,43,00,36,00,41,00,42,00,46,00,38,00,34,00,2d,\
00,37,00,33,00,38,00,30,00,2d,00,34,00,42,00,36,00,30,00,2d,00,41,00,31,00,\
34,00,32,00,2d,00,33,00,42,00,43,00,38,00,37,00,32,00,38,00,42,00,39,00,37,\
00,41,00,37,00,7d,00,00,00,00,00
“UpperBind”=hex(7):4e,00,64,00,69,00,73,00,57,00,61,00,6e,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,31,00,43,\
00,36,00,41,00,42,00,46,00,38,00,34,00,2d,00,37,00,33,00,38,00,30,00,2d,00,\
34,00,42,00,36,00,30,00,2d,00,41,00,31,00,34,00,32,00,2d,00,33,00,42,00,43,\
00,38,00,37,00,32,00,38,00,42,00,39,00,37,00,41,00,37,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0003\Ndi
“Service”=“AsyncMac”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0003\Ndi\Interfaces
“UpperRange”=“ndiswanasync”
“LowerRange”=“nolower”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0004
“MinWanEndpoints”=dword:00000000
“MaxWanEndpoints”=dword:000003e8
“WanEndpoints”=dword:00000005
“Characteristics”=dword:00000029
“ComponentId”=“ms_l2tpminiport”
“InfSection”=“Ndi-Mp-L2tp”
“MatchingDeviceId”=“ms_l2tpminiport”
“DriverDesc”=“WAN Miniport (L2TP)”
“NetCfgInstanceId”="{9F968B81-2805-48D5-B939-B3EFC05F5CBC}"
“EnableForRas”=dword:00000001
“EnableForRouting”=dword:00000000
“EnableForOutboundRouting”=dword:00000000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0004\Linkage
“RootDevice”=hex(7):7b,00,39,00,46,00,39,00,36,00,38,00,42,00,38,00,31,00,2d,\
00,32,00,38,00,30,00,35,00,2d,00,34,00,38,00,44,00,35,00,2d,00,42,00,39,00,\
33,00,39,00,2d,00,42,00,33,00,45,00,46,00,43,00,30,00,35,00,46,00,35,00,43,\
00,42,00,43,00,7d,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,39,00,46,\
00,39,00,36,00,38,00,42,00,38,00,31,00,2d,00,32,00,38,00,30,00,35,00,2d,00,\
34,00,38,00,44,00,35,00,2d,00,42,00,39,00,33,00,39,00,2d,00,42,00,33,00,45,\
00,46,00,43,00,30,00,35,00,46,00,35,00,43,00,42,00,43,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0004\Ndi
“Service”=“Rasl2tp”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0004\Ndi\Interfaces
“UpperRange”=“ndiscowan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0005
“TapiLineName”=“RAS VPN Line”
“InactivityIdleSeconds”=“60”
“TcpPortNumber”=dword:000006bb
“TcpDisconnectTimeout”=dword:0000001e
“TcpConnectTimeout”=dword:0000001e
“ClientIpAddresses”=hex(7):00,00
“ClientIpMasks”=hex(7):00,00
“AuthenticateIncomingCalls”=dword:00000000
“ComponentId”=“ms_pptpminiport”
“InfSection”=“Ndi-Mp-Pptp”
“MatchingDeviceId”=“ms_pptpminiport”
“DriverDesc”=“WAN Miniport (PPTP)”
“NetCfgInstanceId”="{077024CF-CC3A-4B0D-8A8D-E4F5E81E8B93}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0005\Linkage
“RootDevice”=hex(7):7b,00,30,00,37,00,37,00,30,00,32,00,34,00,43,00,46,00,2d,\
00,43,00,43,00,33,00,41,00,2d,00,34,00,42,00,30,00,44,00,2d,00,38,00,41,00,\
38,00,44,00,2d,00,45,00,34,00,46,00,35,00,45,00,38,00,31,00,45,00,38,00,42,\
00,39,00,33,00,7d,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,30,00,37,\
00,37,00,30,00,32,00,34,00,43,00,46,00,2d,00,43,00,43,00,33,00,41,00,2d,00,\
34,00,42,00,30,00,44,00,2d,00,38,00,41,00,38,00,44,00,2d,00,45,00,34,00,46,\
00,35,00,45,00,38,00,31,00,45,00,38,00,42,00,39,00,33,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0005\Ndi
“Service”=“PptpMiniport”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0005\Ndi\Interfaces
“UpperRange”=“ndiswan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0006
“TapiLineName”=“RAS PPPOE Line”
“WanEndpoints”=dword:00000001
“ComponentId”=“ms_pppoeminiport”
“InfSection”=“Ndi-Mp-Pppoe”
“MatchingDeviceId”=“ms_pppoeminiport”
“DriverDesc”=“WAN Miniport (PPPOE)”
“NetCfgInstanceId”="{CE44B845-7924-440A-BA43-5A3E257DE509}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0006\Linkage
“RootDevice”=hex(7):7b,00,43,00,45,00,34,00,34,00,42,00,38,00,34,00,35,00,2d,\
00,37,00,39,00,32,00,34,00,2d,00,34,00,34,00,30,00,41,00,2d,00,42,00,41,00,\
34,00,33,00,2d,00,35,00,41,00,33,00,45,00,32,00,35,00,37,00,44,00,45,00,35,\
00,30,00,39,00,7d,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,43,00,45,\
00,34,00,34,00,42,00,38,00,34,00,35,00,2d,00,37,00,39,00,32,00,34,00,2d,00,\
34,00,34,00,30,00,41,00,2d,00,42,00,41,00,34,00,33,00,2d,00,35,00,41,00,33,\
00,45,00,32,00,35,00,37,00,44,00,45,00,35,00,30,00,39,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0006\Ndi
“Service”=“RasPppoe”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0006\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0007
“MaxWanEndpoints”=dword:00000000
“WanEndpoints”=dword:00000000
“ComponentId”=“ms_ptiminiport”
“InfSection”=“Ndi-Mp-Pti”
“MatchingDeviceId”=“ms_ptiminiport”
“DriverDesc”=“Direct Parallel”
“NetCfgInstanceId”="{6C353F8F-6E60-4993-BAD2-B1A374AF6AAF}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0007\Linkage
“RootDevice”=hex(7):7b,00,36,00,43,00,33,00,35,00,33,00,46,00,38,00,46,00,2d,\
00,36,00,45,00,36,00,30,00,2d,00,34,00,39,00,39,00,33,00,2d,00,42,00,41,00,\
44,00,32,00,2d,00,42,00,31,00,41,00,33,00,37,00,34,00,41,00,46,00,36,00,41,\
00,41,00,46,00,7d,00,00,00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,36,00,43,\
00,33,00,35,00,33,00,46,00,38,00,46,00,2d,00,36,00,45,00,36,00,30,00,2d,00,\
34,00,39,00,39,00,33,00,2d,00,42,00,41,00,44,00,32,00,2d,00,42,00,31,00,41,\
00,33,00,37,00,34,00,41,00,46,00,36,00,41,00,41,00,46,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0007\Ndi
“Service”=“Raspti”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0007\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0008
“ComponentId”=“ms_ndiswanip”
“InfSection”=“Ndi-Mp-Ip”
“MatchingDeviceId”=“ms_ndiswanip”
“DriverDesc”=“WAN Miniport (IP)”
“NetCfgInstanceId”="{7FA716F8-EB58-4125-8D9A-ADFDF63FCC05}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0008\Linkage
“RootDevice”=hex(7):4e,00,64,00,69,00,73,00,57,00,61,00,6e,00,49,00,70,00,00,\
00,00,00
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,4e,00,64,00,69,\
00,73,00,57,00,61,00,6e,00,49,00,70,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0008\Ndi
“BindForm”=“NdisWanIp”
“Service”=“NdisWan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0008\Ndi\Interfaces
“UpperRange”=“ndiswanip”
“LowerRange”=“wan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0009
“EnumExportPref”=dword:00000000
“ComponentId”=“ms_ndiswanbh”
“InfSection”=“Ndi-Mp-Bh”
“MatchingDeviceId”=“ms_ndiswanbh”
“DriverDesc”=“WAN Miniport (Network Monitor)”
“NetCfgInstanceId”="{536601A6-CE20-40DB-9736-4062A2C13795}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0009\Linkage
“RootDevice”=hex(7):4e,00,64,00,69,00,73,00,57,00,61,00,6e,00,42,00,68,00,00,\
00,00,00
“UpperBind”=hex(7):4e,00,4d,00,00,00,00,00
00,73,00,57,00,61,00,6e,00,42,00,68,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0009\Ndi
“BindForm”=“NdisWanBh”
“Service”=“NdisWan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0009\Ndi\Interfaces
“UpperRange”=“ndiswanbh”
“LowerRange”=“wan”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010
“BusNumber”=“0”
“Characteristics”=dword:00000081
“ComponentId”=“root\afs”
“ClientIpAddress”=“3232237572”
“ClientSubnet”=“4294967288”
“DebugLevel”=“0”
“DhcpAddress”=“3232237570”
“NetworkAddress”=“00-15-5E-BA-C0-01”
“RuntimeFlags”=“65536”
“InfPath”=“oem9.inf”
“InfSection”=“AfsAdapter.ndi”
“ProviderName”=“Morgan Stanley Dean Witter, Inc.”
“DriverDateData”=hex:00,c0,57,0c,40,d4,c5,01
“DriverDate”=“10-19-2005”
“DriverVersion”=“1.8.1.21”
“MatchingDeviceId”=“root\afs”
“DriverDesc”=“Morgan Stanley Virtual Ethernet Adapter”
“NetCfgInstanceId”="{50BEFBCB-2046-4294-BB65-AF94D98B8633}"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Linkage
“RootDevice”=hex(7):7b,00,35,00,30,00,42,00,45,00,46,00,42,00,43,00,42,00,2d,\
00,32,00,30,00,34,00,36,00,2d,00,34,00,32,00,39,00,34,00,2d,00,42,00,42,00,\
36,00,35,00,2d,00,41,00,46,00,39,00,34,00,44,00,39,00,38,00,42,00,38,00,36,\
“Export”=hex(7):5c,00,44,00,65,00,76,00,69,00,63,00,65,00,5c,00,7b,00,35,00,30,\
00,42,00,45,00,46,00,42,00,43,00,42,00,2d,00,32,00,30,00,34,00,36,00,2d,00,\
34,00,32,00,39,00,34,00,2d,00,42,00,42,00,36,00,35,00,2d,00,41,00,46,00,39,\
00,34,00,44,00,39,00,38,00,42,00,38,00,36,00,33,00,33,00,7d,00,00,00,00,00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi
“Service”=“AfsAdapter”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\ClientIpAddress
“ParamDesc”=“Adapter client dhcp address allocated”
“Default”=“3232237572”
“Type”=“DWORD”
“Min”=“3232237572”
“Max”=“3232237583”
“Base”=“10”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\ClientSubnet
“ParamDesc”=“Adapter client dhcp subnet mask”
“Default”=“4294967288”
“Type”=“DWORD”
“Min”=“4294967288”
“Max”=“4294967288”
“Base”=“10”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\DebugLevel
“ParamDesc”=“Adapter Debug Level Flags, used only when running debug version”
“Default”=“0”
“Type”=“Enum”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\DebugLevel\enum
“0”=“Error”
“1”=“Warning”
“2”=“Trace”
“3”=“Information”
“4”=“Loud”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\DhcpAddress
“ParamDesc”=“Adapter masquerade dhcp server address”
“Default”=“3232237570”
“Type”=“DWORD”
“Min”=“3232237570”
“Max”=“3232237583”
“Base”=“10”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\NetworkAddress
“ParamDesc”=“Adapter Locally administered Address”
“Default”=“00-15-5E-BA-C0-01”
“Type”=“Edit”
“LimitText”=“12”
“UpperCase”=“1”
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0010\Ndi\Params\RuntimeFlags
“ParamDesc”=“Adapter Runtime Flags”
“Default”=“65536”
“Type”=“DWORD”
“Min”=“0”
“Max”=“65791”
“Base”=“10”
