Yes, I believe that is the case - anything you can use lifecycle with, you should also be able to use Server Automation with. Are you seeing something different? Are you still being limited to 200 endpoints?
Nothing as such . Its just that when we bought we got for 200 Servers. If i want i can enable for all endpoints …but that’s where my question Are we compliant if we are using ?
