I want to add a website in IE 11’s compatibility list, I figured out a way to do it with the registry file. And in order to push it to all users, I want to configure that in BigFix.
I have worked with simple registries with LGPO utility but this is one is difficult.
This is the text from my registry file which adds a website in IE 11 Compatiblity view list if run from desktop directly.
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\BrowserEmulation\ClearableListData]
"UserFilter"=hex:41,1f,00,00,53,08,ad,ba,01,00,00,00,36,00,00,00,01,00,00,00,\
01,00,00,00,0c,00,00,00,9a,4d,5a,b9,2d,ca,d5,01,01,00,00,00,0c,00,65,00,64,\
00,69,00,74,00,72,00,61,00,64,00,65,00,2e,00,63,00,6f,00,6d,00
I need help converting this to LGPO Utility format:
This what I have so far and it didn’t work:
// To use this template, update or remove the following blocks and replace the Relevance
// Enter your action script here
begin prefetch block
add prefetch item name=LGPO.zip sha1=0c74dac83aed569607aaa6df152206c709eef769 size=815660 url=https://download.microsoft.com/download/8/5/C/85C25433-A1B0-4FFA-9429-7E023E7DA8D8/LGPO.zip sha256=6ffb6416366652993c992280e29faea3507b5b5aa661c33ba1af31f48acea9c4
// Download UnZip utility
add prefetch item name=unzip.exe sha1=e1652b058195db3f5f754b7ab430652ae04a50b8 size=167936 url=http://software.bigfix.com/download/redist/unzip-5.52.exe sha256=8d9b5190aace52a1db1ac73a65ee9999c329157c8e88f61a772433323d6b7a4a
collect prefetch items
end prefetch block
// Add LGPO.zip to the client utility cache
utility __Download\LGPO.zip
// Add unzip.exe to the client utility cache
utility __Download\unzip.exe
waithidden __Download\unzip.exe -o "{pathname of client folder of current site}\__Download\LGPO.zip" -d "{pathname of client folder of current site}\__Download"
delete __createfile
createfile until EOF_EOF_EOF
; PARSING COMPUTER POLICY
; Source file: \temp\Registry.pol
User
UserFilter
; PARSING COMPLETED.
EOF_EOF_EOF
delete regpol.txt
move __createfile regpol.txt
waithidden __Download\LGPO.exe /t regpol.txt
continue if {exit code of action = 0}
Please help me fix this.
