KB5001342 not superseded
Just got off phone with MS with a case because KB5001342 was not superseded by KB5003171 but 3 hours after opening case, MS catalog now reflects the superseded chain but Bigfix is not reflecting it.
Do we know if HCL sees this or do I have to open an HCL case?
This seems too quick, we have also been in same situation few time back, HCL will take care this very quickly however if you open case that will speed up the process.
In our case it was on Sat/Sun & during that time period options are always limited.
But for time being you can go with custom task for that KB.
Hello,
There was no supersedence mentioned, when we published it to the external sites, However, We have taken note of the changes made by MS and will modify and release them. will keep you posted.Thank you.
Regards,
Praheeth
A case had to be raised for HCL to be informed that MS updated their supersede chain. I see the updates for KB5001342 rolling into our BF environments now.
