Hi All,
I would like to ask about those two fixlets:
MS18-APR: Cumulative Update for Windows 10 Version 1709 - Windows 10 Version 1709 - KB4093112 (x64)
MS18-APR: Delta Update for Windows 10 Version 1709 - Windows 10 Version 1709 - Delta Update - KB4093112 (x64)
On Microsoft site
https://docs.microsoft.com/en-us/windows-server/administration/windows-server-update-services/deploy/monthly-delta-update-isv-support-without-wsus
there is information that:
“Prevent deployment of Delta and Cumulative updates in the same month”
“If you approve and deploy the same version of the Delta and Cumulative update, you will not only generate additional network traffic since both will be downloaded to the PC, but you may not be able to reboot your computer to Windows after restart.”
As far as I know those fixlets should works in the way that only cumulative or delta is installed (if machine have all patches from previous month only delta will be relevant and will be installed, if not then cumulative will be relevant and installed)
We pushed some patches as action group onto Windows 10 Version 1709 machines and we noticed that both cumulative and delta were installed:
Is this normal behavior?
