Java Versions
(imported topic written by jcochran197791)
I am wondering if there is a way to use Big Fix to locate the versions of Java that are available within our enterprise? Is there an analysis i can create or something?
Are you looking for the Java Runtimes? Does this work for you?
q: values “DisplayName” of keys whose (((it contains “java” OR it contains “j2se”) AND (it contains “runtime environment” OR it contains “update”)) of (value “DisplayName” of it as string as lowercase) ) of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry
A: Java™ SE Runtime Environment 6
(imported comment written by jcochran197791)
Would i create that as a new Analysis? Still learning! But yes i think that is what i am looking for.
This didn’t work when i put it in as an analysis… it’s showing error under Java Version when i view it. Any thoughts?
What is the error? (hover your mouse over the “”)
Honestly when i hover over all it says is no other information is shown?
