I’m trying to update my users versions of Java.
Firstly I’m running the built in fixlet which is having no issues applying the latest Java update.
Following this I’m then running the task to uninstall multiple versions of Java.The task runs without issue and complete reporting back as fixed in bigfix.
When I check the Java control panel on the endpoint it appears to have removed the program but has left User Java settings for the old version (see screenshots).
Is this normal behavior? I apologize in advance if this has been answered previously.
