(imported topic written by jr6591)
I am trying to identify what version of Java are installed. Unfortunately, i get mixed results depending on what criteria I use. The registry for Java does not clean all older versions so some information is not accurate. I ran this on a PC with version 1.5.0_12 and 6.0 (1.6.0_02). I DO NOT have version 1.4 installed at all yet it still shows. And if I use the reg keys, if it has a version then it shows the 1.6 and 1.6.0_02 (it duplicates info as it really only has 1.6.0_12)
regapp shows only the latest version 1.6.0_02 and it shows it as 6.0.20.6 when using regapp
ANy ideas on how I can nail this thing down?
Q: if exists regapp “javaws.exe” then version of regapp “javaws.exe” as string else “Not Installed”
A: 6.0.20.6
Q: regapps “javaws.exe”
A: “javaws.exe” “6.0.20.6” “Java™ Web Start Launcher” “6.0.20.6” “Sun Microsystems, Inc.”
Q: (name of it & " - " & (if (exists version of it) then (version of it as string) else (“No Version”))) of regapps whose (name of it as lowercase contains “ja”)
A: javaws.exe - 6.0.20.6
Q: concatenation ", " of names of keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry
A: 1.4, 1.5, 1.5.0_12, 1.6, 1.6.0_02
Q: if (exists keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry)then (concatenation ", " of names of keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry)else (“Not Installed”)
