I’m working with IVR and after the December update, it’s been working very well. But so far I’m only able to select a vulnerability and see what systems it is applicable. I’d like the option to select a system and see what vulnerabilities are being reported on that system. Is that possible?
There absolutely is a way to view the amount fo vulnerabilities on a particular device. When selecting a vulnerability from the list at the bottom of the page it brings up the Description page. Default brings you to the “Vulnerability Information” section of the vulnerability you selected. Across the top of that page just under the Vulnerability name you will see “Contents”, “Devices”, “Deployments”.
Clicking on devices will bring you to the list of all devices that are showing relevant to the vulnerability. Selecting a device will drill further into that device and bring up the information page of the device. Along the right side of the screen you will see a box labeled “Activities” where you can see the amount of either Critical Deployments or Failed Deployments.
Selecting the Vulnerabilities link will bring another list of all of the vulnerabilities on that device given that there are critical vulnerabilities on that device.
You can also view the vulnerability information from the device from the device section of the WebUI.
Thanks. I guess I was getting confused because I’m told 0 Critical Vulnerabilities in Activities but when I click on it those that have some will list them.
