yes that is the link it is the general one.
here is the contents of the powershell script
# Copyright (c) Microsoft Corporation.
# Licensed under the MIT License.
# THE SOFTWARE IS PROVIDED *AS IS*, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
Param (
[Parameter(HelpMessage = "Work Directory for patch WinRE")][string]$workDir = ""
# Help functions
# Log message
function LogMessage([string]$message) {
$message = "$([DateTime]::Now) - $message"
Write-Host $message
function TargetfileVersionExam([string]$mountDir) {
# Exam target binary
$targetBinary = $mountDir + "\Windows\System32\bootmenuux.dll"
LogMessage("TargetFile: " + $targetBinary)
$realNTVersion = [Diagnostics.FileVersionInfo]::GetVersionInfo($targetBinary).ProductVersion
$versionString = "$($realNTVersion.Split('.')[0]).$($realNTVersion.Split('.')[1])"
$fileVersion = $($realNTVersion.Split('.')[2])
$fileRevision = $($realNTVersion.Split('.')[3])
LogMessage("Target file version: " + $realNTVersion)
if (!($versionString -eq "10.0")) {
LogMessage("Not Windows 10 or later")
return $False
$needsUpdate = $False
#Windows 10, version 1507 10240.19567
#Windows 10, version 1607 14393.5499
#Windows 10, version 1809 17763.3646
#Windows 10, version 2004 1904X.2247
#Windows 11, version 21H2 22000.1215
#Windows 11, version 22H2 22621.815
switch ($fileVersion) {
"10240" {
LogMessage("Windows 10, version 1507")
if ($fileRevision -ge 19567) {
LogMessage("Windows 10, version 1507 with revision " + $fileRevision + " >= 19567, updates have been applied")
$needsUpdate = $True
break
"14393" {
LogMessage("Windows 10, version 1607")
if ($fileRevision -ge 5499) {
LogMessage("Windows 10, version 1607 with revision " + $fileRevision + " >= 5499, updates have been applied")
break
"17763" {
LogMessage("Windows 10, version 1809")
if ($fileRevision -ge 3646) {
LogMessage("Windows 10, version 1809 with revision " + $fileRevision + " >= 3646, updates have been applied")
break
"19041" {
LogMessage("Windows 10, version 2004")
if ($fileRevision -ge 2247) {
LogMessage("Windows 10, version 2004 with revision " + $fileRevision + " >= 2247, updates have been applied")
break
"22000" {
LogMessage("Windows 11, version 21H2")
if ($fileRevision -ge 1215) {
LogMessage("Windows 11, version 21H2 with revision " + $fileRevision + " >= 1215, updates have been applied")
break
"22621" {
LogMessage("Windows 11, version 22H2")
if ($fileRevision -ge 815) {
LogMessage("Windows 11, version 22H2 with revision " + $fileRevision + " >= 815, updates have been applied")
break
default {
LogMessage("Warning: unsupported OS version")
return $needsUpdate, $fileVersion, $fileRevision
# Execution starts
# Check breadcrumb
New-Item "C:\Users\Public\company\Logs" -ItemType Directory | Out-Null
Start-Transcript -Path "C:\Users\Public\company\Logs\WinREversion.log" -Append
if (Test-Path HKLM:\Software\Microsoft\PushButtonReset) {
$values = Get-ItemProperty -Path HKLM:\Software\Microsoft\PushButtonReset
if (!(-not $values)) {
if (Get-Member -InputObject $values -Name WinREPathScriptSucceed) {
$value = Get-ItemProperty -Path HKLM:\Software\Microsoft\PushButtonReset -Name WinREPathScriptSucceed
if ($value.WinREPathScriptSucceed -eq 1) {
LogMessage("This script was previously run successfully")
Stop-Transcript
exit 1
if ([string]::IsNullorEmpty($workDir)) {
LogMessage("No input for mount directory")
LogMessage("Use default path from temporary directory")
$workDir = [System.IO.Path]::GetTempPath()
LogMessage("Working Dir: " + $workDir)
$name = "CA551926-299B-27A55276EC22_Mount"
$mountDir = Join-Path $workDir $name
LogMessage("MountDir: " + $mountdir)
# Delete existing mount directory
if (Test-Path $mountDir) {
LogMessage("Mount directory: " + $mountDir + " already exists")
LogMessage("Try to unmount it")
Dism /unmount-image /mountDir:$mountDir /discard
if (!($LASTEXITCODE -eq 0)) {
LogMessage("Warning: unmount failed: " + $LASTEXITCODE)
LogMessage("Delete existing mount direcotry " + $mountDir)
Remove-Item $mountDir -Recurse
# Create mount directory
LogMessage("Create mount directory " + $mountDir)
New-Item -Path $mountDir -ItemType Directory
# Set ACL for mount directory
LogMessage("Set ACL for mount directory")
icacls $mountDir /inheritance:r
icacls $mountDir /grant:r SYSTEM:"(OI)(CI)(F)"
icacls $mountDir /grant:r *S-1-5-32-544:"(OI)(CI)(F)"
# Mount WinRE
LogMessage("Mount WinRE:")
reagentc /mountre /path $mountdir
if ($LASTEXITCODE -eq 0) {
# Check WinRE version and if it needs to be updated
# 3 OUTPUTS: $needsUpdate, $fileVersion, $fileRevision
$needsUpdate, $fileVersion, $fileRevision = TargetfileVersionExam($mountDir)
LogMessage("File version: $fileVersion.$fileRevision" + ", already patched: " + $needsUpdate);
LogMessage("Unmount failed: " + $LASTEXITCODE)
Stop-Transcript
exit 1
else {
LogMessage("Mount failed: " + $LASTEXITCODE)
# Cleanup Mount directory in the end
LogMessage("Delete mount direcotry")
Stop-Transcript
