The WebUI will not open today? It says it is initializing. Has anybody seen this before?
It finally came up
Not sure why that happened
It finally came up
This message is normal if the bes root service service had recently been started. Once the root server has started, it will eventually starts the WebUI processes (several node.exe instances and a bigfix-webui-etl.exe process) and when the ETL has completed, the login screen should appear. Depending on the size on your deployment, that could take several minutes.
Regs
Rob
Yes we just upgraded our environment and are new to the UI. Thanks for the heads up
