Rpm Package Name: BESAgent-9.5.0.311-rhe5.x86_64.rpm
Folder /var/opt/BESInstallers/Console successful populated …
Folder /var/opt/BESInstallers/Client successful populated …
Info: The configuration file ‘/opt/BESServer/bin/BESAdmin.sh’ was created successfully.
Info: The configuration file ‘/opt/BESServer/bin/BESAdmin.sh_bkp’ was created successfully.
Info: The configuration file ‘/opt/BESServer/bin/Airgap.sh’ was created successfully.
Info: The configuration file ‘/opt/BESServer/bin/Airgap.sh_bkp’ was created successfully.
Found section: [SoftwareBigFixEnterpriseClientSettingsClient_BESRelay_HTTPServer_LogFilePath] in '/var/opt/BESServer/besserver.config’
Found key: value = /var/log/BESRelay.log
Info: Configuring the database for the server component, please wait …
/opt/BESServer/bin/BESAdmin.sh -upgrade -sitePvkLocation:"/home/epmgr/IEM-License/license.pvk" -sitePvkPassword:"********"
Force still running BES applications
Upgrade database to version Enterprise 8.01
Upgrade database to version Enterprise 8.02
Upgrade database to version Enterprise 8.04
SQL0104N An unexpected token “!” was found following “”.
Expected tokens may include: “NEW”. SQLSTATE=42601
Some error occured on the selectProcess process for QUESTIONRESULTS
Error: An error occurred while configuring the database for the server component.
I would generally recommend that if you are going to upgrade to 9.5.x that you should upgrade to whatever the newest version of 9.5.x that is available at the time, which should have been 9.5.2.56.
This goes for any version upgrade of BigFix, upgrade to the newest patch level of that Major.Minor version you are upgrading to.
As the upgrade to 9.5…x is a manual process, you would have entered your license.pvk file password to begin updation. I guess your password contains ‘!’ or some other special character.
I suggest you change your password to not have any special character and then try upgrade again.
For your current situation you might have to re-install BigFix again.
