Hi all,
I’ve a WEB application ( Mirò ). Is it possible to discover the use of a license of this type within the BigFix Inventory?
I’m not familiar with the product. Is it a self-hosted application (running on one of your own servers)? Is there a client component installed or any way to detect its usage at the client?
To add to Jason’s suggestions, if it reliably generates cookies with particular data you might be able to scan for those.
Ok, it’s clear, I must necessarily have a confirmation of the fact that the product is present or in any case has been executed on the endpoint in order to be able to “inventory” it. Sophia’s suggestion of generating cookies that track its execution may be a fair compromise.
Thanks to both of you
