I want to create an automation step by creating a dashboard in IEM Console. I am already aware of the .ojo file for wizard, however i am looking for a more advance solution for this automation.
I think you can create dashboards by adding .ojo files to custom sites. Does that not work? Or maybe I don’t understand what you mean by more advanced solution.
The .ojo file i was using required few .js files and hence it was not working however there are few .ojo files (available on forums) which works just fine by adding it to the custom sites.
