Hi ,
I have a problem about webui in IE browser. When I want to deploy an software package , client list doesnt shown. This problem is on only Internet Explorer (Version 11) .
Chrome , mozilla and Edge browser don’t have this problem. Maybe some policies affecting this problem.
Apps–> Custom → Select package–> Deploy
After clicking deploy button client list doesnt shown. You can see the screenshot and console errors.
SCRIPT5022: [$injector:modulerr] Failed to instantiate module bfWorkflow due to:
Error: [$injector:modulerr] Failed to instantiate module ui.router due to:
Error: [$injector:modulerr] Failed to instantiate module ui.router.init due to:
TypeError: Object doesn’t support property or method ‘find’
at getParamDeclaration (https://:444/takeaction/lib/libs.js:16189:9)
at Param (https://:444/takeaction/lib/libs.js:16253:13)
at ParamFactory.prototype.fromConfig (https://:444/takeaction/lib/libs.js:19630:13)
at makeConfigParam (https://:444/takeaction/lib/libs.js:17318:59)
at Anonymous function (https://:444/takeaction/lib/libs.js:15101:50)
at forEach (https://:444/takeaction/lib/libs.js:29613:11)
at map (https://:444/takeaction/lib/libs.js:15101:9)
at paramsBuilder (https://:444/takeaction/lib/libs.js:17320:13)
at Anonymous function (https://:444/takeaction/lib/libs.js:17515:105)
at StateBuilder.prototype.build (https://:444/takeaction/lib/libs.js:17516:17)
AngularJS’%0A%20%20%20at%20getParamDeclaration%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A16189%3A9)%0A%20%20%20at%20Param%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A16253%3A13)%0A%20%20%20at%20ParamFactory.prototype.fromConfig%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A19630%3A13)%0A%20%20%20at%20makeConfigParam%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A17318%3A59)%0A%20%20%20at%20Anonymous%20function%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A15101%3A50)%0A%20%20%20at%20forEach%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A29613%3A11)%0A%20%20%20at%20map%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A15101%3A9)%0A%20%20%20at%20paramsBuilder%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A17320%3A13)%0A%20%20%20at%20Anonymous%20function%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A17515%3A105)%0A%20%20%20at%20StateBuilder.prototype.build%20(https%3A%2F%2F*********************%3A444%2Ftakeaction%2Flib%2Flibs.js%3A17516%3A17)
at Anonymous function (https://:444/takeaction/lib/libs.js:34146:9)
at forEach (https://:444/takeaction/lib/libs.js:29599:11)
at loadModules (https://:444/takeaction/lib/libs.js:34106:5)
at Anonymous function (https://:444/takeaction/lib/libs.js:34124:11)
at createInjector (https://:444/takeaction/lib/libs.js:34028:3)
