I have tested multiple attempts to run using BigFix - the action shows running but there is no activity . I attempted to run from the download folder and then I attempted to copy to directory and run from there same issue every time. there is no error in relevance command . I turned on verbose logging and don’t see the issue.
log file
Search “splunk” (28 hits in 1 file of 1 searched) [RegEx]
C:\Users\johngib\OneDrive - CDW\Documents\besclientdebug.log (28 hits)
Line 233: Fri, 29 Nov 2024 12:15:48 -0600 DebugMessage Relevant - Software Distribution - Deploy: Splunk (fixlet:103961)
Line 242: Fri, 29 Nov 2024 12:15:49 -0600 DebugMessage ActionLogMessage: (action:103961) Download url: ‘http://SHSEGVBFXPVW002.forsythehosting.com:52311/Uploads/44b1998a0b527aa868bfc0e3f18bd186b4092601/splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi.tmp’
Line 347: Fri, 29 Nov 2024 12:17:39 -0600 DebugMessage Command succeeded (Prefetch download manager collected file) prefetch 44b1998a0b527aa868bfc0e3f18bd186b4092601 sha1:44b1998a0b527aa868bfc0e3f18bd186b4092601 size:129245467 http://SHSEGVBFXPVW002.forsythehosting.com:52311/Uploads/44b1998a0b527aa868bfc0e3f18bd186b4092601/splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi.tmp sha256:5c8ac79ae89447a8e6e9c147ac0bc6016cb36041c773c73fa651170b0d427f59 (action:103961)
Line 357: Fri, 29 Nov 2024 12:17:42 -0600 VerboseMessage RelevanceSubstitution::SubstituteStrings() entering, input = “{pathname of system folder & “\msiexec.exe”}” /i “c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log" /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes
Line 362: Fri, 29 Nov 2024 12:17:42 -0600 DebugMessage Command started - waithidden “C:\Windows\system32\msiexec.exe” /i "c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log” /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes (action:103961)
Line 672: Fri, 29 Nov 2024 12:27:15 -0600 DebugMessage Command failed (Action ended while waiting for another process to complete) waithidden “{pathname of system folder & “\msiexec.exe”}” /i “c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log" /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes (action:103961)
Line 841: Fri, 29 Nov 2024 12:29:39 -0600 DebugMessage Relevant - Software Distribution - Deploy: Splunk (fixlet:103962)
Line 962: Fri, 29 Nov 2024 12:30:23 -0600 DebugMessage ActionLogMessage: (action:103962) Download url: ‘http://SHSEGVBFXPVW002.forsythehosting.com:52311/Uploads/44b1998a0b527aa868bfc0e3f18bd186b4092601/splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi.tmp’
Line 969: Fri, 29 Nov 2024 12:30:30 -0600 DebugMessage Command succeeded (Prefetch download manager collected file) prefetch 44b1998a0b527aa868bfc0e3f18bd186b4092601 sha1:44b1998a0b527aa868bfc0e3f18bd186b4092601 size:129245467 http://SHSEGVBFXPVW002.forsythehosting.com:52311/Uploads/44b1998a0b527aa868bfc0e3f18bd186b4092601/splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi.tmp sha256:5c8ac79ae89447a8e6e9c147ac0bc6016cb36041c773c73fa651170b0d427f59 (action:103962)
Line 977: Fri, 29 Nov 2024 12:30:36 -0600 VerboseMessage RelevanceSubstitution::SubstituteStrings() entering, input = “{pathname of system folder & “\msiexec.exe”}” /i "{(pathname of client folder of current site) & "__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log”}" /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes
Line 981: Fri, 29 Nov 2024 12:30:36 -0600 VerboseMessage RelevanceSubstitution::EvaluateRelevanceAsString() entering, input = (pathname of client folder of current site) & “__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log"
Line 985: Fri, 29 Nov 2024 12:30:36 -0600 DebugMessage Command started - waithidden “C:\Windows\system32\msiexec.exe” /i "C:\Program Files (x86)\BigFix Enterprise\BES Client__BESData\CustomSite_Gibson_Custom_Content__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /lv C:\TEMP\SplunkInstall.log” /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes (action:103962)
That message indicates the client was restarted while the ‘waithidden’ command was still running.
I see you downloading a .msi.tmp file, but not where you extract or rename it to take the .tmp off the filename; and then you’re running msiexec against a file in c:\Temp but I don’t see where you would have moved the MSI package to the temp directory. Normally you would reference that with the relative path __Download\filename.msi
Jason below are the two options I have used to run from the client download foler or copy the installer to c:temp directory and run from there. Interesting you say the client restarted during the process . where did you see that as that seems like it would casuse the process issue
Copying the file to the C:temp directory .
//copy “{(client folder of current site as string) & “__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi”}” “c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi”
This is running from the client directory
//waithidden “{pathname of system folder & “\msiexec.exe”}” /i “c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /l*v C:\TEMP\SplunkInstall.log” /qn /norestart
//waithidden “{pathname of system folder & “\msiexec.exe”}” /i “{(pathname of client folder of current site) & “__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /l*v C:\TEMP\SplunkInstall.log”}” /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes
This is running from the C:Temp directory
//waithidden “{pathname of system folder & “\msiexec.exe”}” /i “c:\Temp\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi /l*v C:\TEMP\SplunkInstall.log” /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes
That copy command won’t be correct - ‘client folder of current site as string’ will not contain the trailing backslash, so the string will be some thing like “c:\BES\client__BESData\CustomSite_MySiteName__Download\splunkforwarder-9.2.3-something.msi”
Missing the "" between sitename and __Download.
Please grab an excerpt of the client log while this action is running so we can see how all of the relevance substitutions are evaluated.
so I attempted to use the custom site to install but now getting ActionLogMessage: (action:104314) Action signature verified for Execution
ActionLogMessage: (action:104314) Cannot empty _Download directory
So I have deleted the folder from the custom site 104314 and have used task to clear the cached and stop and started client. none changes this issue. So I then changed to the master action site and the process is stuck just running which is what always happens.
It’s still missing the backslash between the site name and the __Download folder that I suggested could be a problem earlier - and now it looks like you have several Unicode extended versions of “smart quotes”, look for those in the log file to show where the characters are incorrect
With a bad path to the MSI package, the msiexec command is likely just promoting you an error message; but since the interface is hidden, you cannot see or dismiss the message, so the msiexec is stuck running and has the folders locked.
Jason can you show me what you mean with this exampl
You may need to retype all the double quotes, I’m typing on my phone now but what I mean is this…note the backslash before __Download. I also changed some of the quoting. I can’t test this but try
waithidden "{pathname of system folder}\msiexec.exe" /i "{(pathname of client folder of current site)}\__Download\splunkforwarder-9.2.3-282efff6aa8b-x64-release.msi" /l*v C:\TEMP\SplunkInstall.log /qn /norestart / WINEVENTLOG_SYS_ENABLE=1 SPLUNKPASSWORD=LearnSplunk AGREETOLICENSE=yes
No matter what i do including just running the .exe only it , the action continues to run and never stop and yet its not writing to log file or running any action that I can tell. this should not be this difficult. I keyed in exactly the above from Jason making sure no characters or " issues. Yet it just stay in state of running . does anyone have maybe a PS1 script that would run the above process? Or some way to detect what the run process is doing?
A PowerShell wrapper would just complicate things, you still need to get the working msiexec command line.
Can you provide the whole script that you’re trying now? We’ve talked about several changes so far and I don’t know if any were missed or incorrect.
The process staying in the state of ‘running’ usually means that either a confirmation message or an error message is trying to display, but since the user interface is hidden it cannot be shown on the screen.
And when you try to run it manually?
I don’t have Splunk handy anymore, I can’t test the command line, I’m basing all the parameters off of what you provided.
