Installation of remote controller
We want to manually install the BigFix Remote Controller and Target on some systems where the BigFix client is not present. Please guide us on how to perform the installation and specify which files and certificates are required.
Hello abc123,
For the installation of Controller and Target component you can follow the instructions in the component installation guide:
The Controller doesn’t need any special setting while the Target can be configured by following the instructions in this guide:
If you are using a Remote Control server and you want to register the Targets you can follow the instructions reported here:
