Are there any pros or cons as far as installing the BigFix clients on all the remote servers before installing ILMT?
In the instructions, there appears to be a choice and not sure which is the better option or if it matters.
Thanks, Brent
Installing the Clients first will make installing and configuring LMT simpler. There are a number of tasks that you need to run from the BigFix Console to install and configure scanners for LMT, and you cannot do so without the clients reporting into BigFix.
That is great advice and exactly what I was looking for! Thank you for the quick response!
