Is it supported or possible to install BigFix and ILMT using Azure SQL instead of using a dedicated SQL server.
In other words just access to database instances insted of a dedicated server running SQL server.
I’m not able to find any documentation regarding this topic.
Possibly possible, very unlikely to be supportable.
I know customers using Amazon’s RDS database service have been unable to run BES Server platform upgrades because they are unable to obtain the db_owner role necessary during the database/schema upgrade.
Sure, the official statement is in the “Supported Platforms” and “Supported Databases” section of the system requirements. Amazon RDS is not a supported platform for the database.
Thank you for your quick response. So i assume that azure SQL is also not supported platform for the database as i do not find that in “supported database” section of system requirement.
Agree, I also assume that azure sql is not supported. I tried to open a ticket to get an “official statement”, but they only referred to the documentation.
