i’ve now tried importing the install.wim from the windows 10 iso downloaded from microsoft that trows an
[2021/01/11 17:28:51:931] Bare Metal Server for BigFix OS deployment Web extension 64 bits v.7.1.1.20 (310.78)
[2021/01/11 17:28:51:931] © Copyright HCL Technologies Limited 2000, 2020.
[2021/01/11 17:28:51:931] All Rights Reserved. HCL, the HCL logo, and BigFix are trademarks of HCL Technologies Limited in the United States, other countries or both.
[2021/01/11 17:28:52:431] Bootable: \.\PHYSICALDRIVE0
[2021/01/11 17:28:52:462] Device \.\PhysicalDrive0 (0:0) is a regular disk
[2021/01/11 17:28:52:462] Device size: 52428800 KB
[2021/01/11 17:28:52:462] Hard disk geometry: ff 3f
[2021/01/11 17:28:52:462] Non-USB: \.\PhysicalDrive0
[2021/01/11 17:28:52:462] Device \.\PhysicalDrive1 (0:1) is a regular disk
[2021/01/11 17:28:52:462] Device size: 104857600 KB
[2021/01/11 17:28:52:462] This disk geometry: ff 3f
[2021/01/11 17:28:52:462] Non-USB: \.\PhysicalDrive1
[2021/01/11 17:28:52:478] Running in offline mode
[2021/01/11 17:28:52:509] A LoadPakUtils: loading from rbagent.pak
[2021/01/11 17:28:52:509] A LoadPakUtils: successfully loaded
[2021/01/11 17:28:52:728] A Loading server extensions if available
[2021/01/11 17:28:52:728] A Working in offline, extensions are disabled
[2021/01/11 17:28:52:744] A No ServerID has been defined
[2021/01/11 17:28:52:822] A Selected temporary folder: ‘local://temp/tpm_E0A98711AFFDCD1D_1’
[2021/01/11 17:28:52:822] A Mounting install.wim index 1
[2021/01/11 17:28:53:462] WIM library loaded
[2021/01/11 17:32:27:224] WIMUnMount(“C:\Users\user\AppData\Local\Temp\tpm_E0A98711AFFDCD1D_1”,0)
[2021/01/11 17:36:15:581] Error c1420117 while attempting to unmount image
[2021/01/11 17:36:16:362] A Command error: Archive inconsistency detected, Error c1420117 while attempting to unmount image
[2021/01/11 17:36:16:362] A Error raised by WIMWait in pakutils.rbc, line 423 [@SY:7780]
[2021/01/11 17:36:16:362] A Archive inconsistency detected (Error c1420117 while attempting to unmount image )
[2021/01/11 17:36:16:362] A (called from unmount (pakutils.rbc:688))
[2021/01/11 17:36:16:362] A (called from CheckVistaState (pakutils.rbc:813))
[2021/01/11 17:36:16:362] A (called from WIMGetImageDescriptions (pakutils.rbc:557))
[2021/01/11 17:36:16:362] A (called from generateWinImageInfo (load.rbc:14555))
[2021/01/11 17:36:16:362] A (called from OSDT_ExtractWIMInfo (load.rbc:2336))
[2021/01/11 17:36:16:362] A (called from AgentDispatch (rbagent.rbc:4398))
[2021/01/11 17:36:16:362] A (called from --toplevel-- (rbagent.rbc:4825))
[2021/01/11 17:36:16:362] A RbAgent command osdtools-extractwiminfo has failed [AGT:4405]
and while targetting the extracted iso it trows
[2021/01/11 18:21:19:137] Bare Metal Server for BigFix OS deployment Web extension 64 bits v.7.1.1.20 (310.78)
[2021/01/11 18:21:19:137] © Copyright HCL Technologies Limited 2000, 2020.
[2021/01/11 18:21:19:152] All Rights Reserved. HCL, the HCL logo, and BigFix are trademarks of HCL Technologies Limited in the United States, other countries or both.
[2021/01/11 18:21:19:496] Bootable: \.\PHYSICALDRIVE0
[2021/01/11 18:21:19:512] Device \.\PhysicalDrive0 (0:0) is a regular disk
[2021/01/11 18:21:19:512] Device size: 52428800 KB
[2021/01/11 18:21:19:512] Hard disk geometry: ff 3f
[2021/01/11 18:21:19:512] Non-USB: \.\PhysicalDrive0
[2021/01/11 18:21:19:527] Device \.\PhysicalDrive1 (0:1) is a regular disk
[2021/01/11 18:21:19:527] Device size: 104857600 KB
[2021/01/11 18:21:19:527] This disk geometry: ff 3f
[2021/01/11 18:21:19:527] Non-USB: \.\PhysicalDrive1
[2021/01/11 18:21:19:543] Running in offline mode
[2021/01/11 18:21:19:574] A LoadPakUtils: loading from rbagent.pak
[2021/01/11 18:21:19:574] A LoadPakUtils: successfully loaded
[2021/01/11 18:21:19:793] A Loading server extensions if available
[2021/01/11 18:21:19:793] A Working in offline, extensions are disabled
[2021/01/11 18:21:19:808] A No ServerID has been defined
[2021/01/11 18:21:19:902] A Selected temporary folder: ‘local://temp/tpm_9C746C8695FD7214_1’
[2021/01/11 18:21:19:902] A Mounting install.wim index 1
[2021/01/11 18:21:20:527] WIM library loaded
[2021/01/11 18:24:53:462] WIMUnMount(“C:\Users\user\AppData\Local\Temp\tpm_9C746C8695FD7214_1”,0)
[2021/01/11 18:28:45:884] Error c1420117 while attempting to unmount image
[2021/01/11 18:28:46:587] A Command error: Archive inconsistency detected, Error c1420117 while attempting to unmount image
[2021/01/11 18:28:46:587] A Error raised by WIMWait in pakutils.rbc, line 423 [@SY:7780]
[2021/01/11 18:28:46:587] A Archive inconsistency detected (Error c1420117 while attempting to unmount image )
[2021/01/11 18:28:46:587] A (called from unmount (pakutils.rbc:688))
[2021/01/11 18:28:46:587] A (called from CheckVistaState (pakutils.rbc:813))
[2021/01/11 18:28:46:587] A (called from WIMGetImageDescriptions (pakutils.rbc:508))
[2021/01/11 18:28:46:587] A (called from generateWinImageInfo (load.rbc:14555))
[2021/01/11 18:28:46:587] A (called from generateWinImageInfoForSetupImage (load.rbc:15920))
[2021/01/11 18:28:46:587] A (called from RAD_temmksetup (load.rbc:16097))
[2021/01/11 18:28:46:587] A (called from AgentDispatch (rbagent.rbc:4398))
[2021/01/11 18:28:46:587] A (called from --toplevel-- (rbagent.rbc:4825))
[2021/01/11 18:28:46:587] A RbAgent command rad-temmksetup has failed [AGT:4405]
