Is there any update or change in the behavior of IEM CLI execution with system user.
I have been trying to run multiple automation out of BigFix task based on IEM CLI but the problem is IEM CLI can 't be invoked with system user and for that reason either you manually run the program with IEMCLI or schedule task.
cURL is useful but the problem is IEM CLI can read same XML very easily where cURL mostly throw error with invalid XML, and working on XML structure again is huge task when knowing its working with IEM CLI.
