IEM 9.1.1.229 Agent Silent Installation on Aix/Solaris
Can anyone help us for bes agent silent installation on Aix/Solaris Server.
There is no real “silent” install but stdout/stderr could be redirected.
The commands are all at: http://support.bigfix.com/bes/install/besclients-nonwindows.html
Hi Alan,
Can we have any bash script to achieve it.
Yes. If you look at the upgrade fixlets you will see that they actually do use a shell script to do their work. Installs can be done the same way and are essentially what the installer that is in BigFix Labs uses on UNIX platforms
